928 Forum 1978-1995
Sponsored by: 928 Specialists
Overheat...
Old 07-19-2012, 03:58 PM
  #31
Puppy
Puppy's Avatar
Well I just got the repair manual in the mail (thankfully I ordered it when I bought the car), here we go.
Old 07-19-2012, 03:59 PM
  #32
Mongo
Official Bay Area Patriot
Fuse 24 Assassin
Mongo's Avatar
Good luck. You will know exactly what happened as soon as you pull those timing belt covers off. I have my fingers crossed for you.
Old 07-19-2012, 04:27 PM
  #33
ALKada
ALKada's Avatar
Check Dwaynes write ups with great pics for help. http://dwaynesgarage.norcal928.org/
Like most of the guys on this forum, he goes above and beyond to help others.
Old 07-19-2012, 05:08 PM
  #34
jeff spahn
jeff spahn's Avatar
+1 on Dwayne. I used his as a guide when i pulled my engine and did all the work. Rob Edwards is your source for what an engine is supposed to look like when new. His basically is.
Old 07-19-2012, 06:10 PM
  #35
Barry Chan
Barry Chan's Avatar
i like your attitude, nothing is impossible, welcome to the forum,
have fun and good luck
Old 07-19-2012, 06:44 PM
  #36
mickster
mickster's Avatar
You're going to fit in just fine here...
Old 07-19-2012, 07:37 PM
  #37
fbarnhill
fbarnhill's Avatar
Hey puppy, you got off better than I did with my 88s4 'Steal'. It was my favorite car ever and I have had 5 928s now. Mine just caught fire and burned right in my garage just 5 minutes after I got her running perfectlly. Pay close attention to those fuel lines once you get into the engine. I then bought my 86.5 with the same issue you are having now. I rebuilt the engine. Not too bad and had a ton of fun. I am in NC and if I can help in any way, pm me and I will send you my phone number. If you are a pretty good wrench you can do 95% alone. I needed help getting the new engine in the car. That was to help guide it between the motor mounts. I then made another stupid mistake by hooking up the battery charger to the battery in startup mode. That messed up the ECU. So, you are pre-warned about that one. It was middle of the night, I had worked on it all day and wanted to hear it run. soooo... I heard it run 3 weeks later. Now I love it almost as much as my 88.
Good luck,
Old 07-19-2012, 07:47 PM
  #38
Imo000
Captain Obvious
Super User
Imo000's Avatar
Originally Posted by Puppy
No, only the coolant one.
Sounds like the timing belt tension warning system has been bypassed then. That sucks!!
Old 07-19-2012, 07:50 PM
  #39
namasgt
namasgt's Avatar
Definitely do all the rubber fuel lines. Call Roger at 928s RUS, he sells a kit.
Old 07-19-2012, 08:32 PM
  #40
Ondolinde
Ondolinde's Avatar
Good luck!
Old 07-19-2012, 09:02 PM
  #41
jwillman
jwillman's Avatar
join rennlist and 928 OC. The abilty to post pictures will be invaluable. Good luck and don't forget to enjoy the challenge. It will help you avoid the disenchantment that befalls many.
Old 07-19-2012, 09:27 PM
  #42
Hilton
Hilton's Avatar
edit: removed wrong info on 87 being non-interference - the car I thought survived belt failure compression-tested ok, and ran ok. Leakdown however a couple of months later showed bent valves
Now that you have a manual, its time to dig in
Pull the timing belt system apart and check it all out.
My first goal in your shoes would be to put in a replacement water pump (any pump where the pulley turns), string a new belt, and then use the starter to run a compression test on each cylinder.
That will give you the information you need to decide what to do next.. before you end up with parts bills totalling more than the cost of a replacement S4 engine
Old 07-19-2012, 10:37 PM
  #43
Imo000
Captain Obvious
Super User
Imo000's Avatar
Leakdown test is much more accurate than a compression test and you don't need to spin the engine. I think that S4you guys had there was an extremely lucky owner. As far as I know, All 32Vs will bend the valves, pretty much all the time the belt let's go.
Old 07-20-2012, 12:00 AM
  #44
Hilton
Hilton's Avatar
Agree on leakdown - but performing one requires more expensive gear to find than a compression test.
Old 07-20-2012, 04:32 AM
  #45
Podguy
Podguy's Avatar
all 32 valve engines are interference engines.
It is possible the tension light was not triggered as the belt did not break. If it just lost teeth becuase of a froze water pump then the tension would remain correct or within limits. It happened on my car without the pump freezing - just a very old belt.
Not to scare you but there could be worse problems than a bad pump and bent valves. The impeller could have come off and ground into the block.
Quick Reply: Overheat...
