New Product: Precision Motorwerks Crankcase Ventilation Kit
#61
Greg: Thanks for the info. It just turned over 80K. Would Techron qualify as carbon softener? I ran a tank with that on this last trip; planning on doing some more.
#62
Basic Site Sponsor
Basic Site Sponsor
I'd run something more aggressive, like Liqui Moly valve cleaner, Berryman B-12 Chemtool fuel system cleaner, or SeaFoam, in the fuel tank.
I've sucked B-12 Chemtool right into the intake system....and allowed the engine to almost stall. I then allow the engine to sit for 24 hours (soak) and then restart, immediately getting it warm and driving hard.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
#63
Administrator - "Tyson"
Have you developed such a kit for the 16V cars?
#64
Basic Site Sponsor
Basic Site Sponsor
Yes, but no.
An example is on Van's stroker and works fantastic. I'm not using a Mann filter in this application, (because a filter needs to be serviced routinely and that costs money.) Therefore, tiny amounts of oil mist can be found on the plenum walls (looks like someone lightly sprayed WD40 on parts of the walls, but no drips and certainly no puddles form.
I call that 99% effective at removing the oil from the intake air, while still having a closed crankcase. Pretty amazing improvement.
The problem, in terms of a kit being available:
I'm really tired of doing 100's of hours of research and development, creating custom pieces, and testing stuff for extended periods of time, only to have some crook/crooks copy my work.
It is amazingly cheap to copy, instead of creating! I get it. When there is no developmental costs to try to recover, the profit margin of copied stuff is huge!
Therefore, this system and the proprietary pieces that make this system work will only be available in house.
I've also made changes to the system referenced in this thread....eliminating the Mann filter to eliminate the service requirement of that filter, as well as adding in some of the proprietary pieces invented for the S3 system. I no longer sell that system to the general public, either.
#65
Yes, but no.
An example is on Van's stroker and works fantastic. I'm not using a Mann filter in this application, (because a filter needs to be serviced routinely and that costs money.) Therefote, tiny amounts of oil mist can be found on the plenum walls (looks like someone lightly sprayed WD40 on parts of the walls, but no drips and certainly no puddles form.
Therefote, this system and the proprietary pieces that make this system work will only be available in house.
I understand about development costs and loosing that to those that copy. I'm just bummed that it can't be purchased. I would really prefer a sealed system that doesn't coat the intake with oil and doesn't require the Mann filter. I'm stuck buying one off pieces and building my own that may take years to hit on the winning combination if ever.
#66
Have you seen the stainless steel filter element for the Provent?
Works perfectly on the GT racecar with its output going directly to the intake thru the metered plastic plug which is normally on the 87's oil fill neck.
Input is from 1" outlet on oil filler cap. The front valve-cover ports are connected to one another, as well as the rear valve-cover ports.
Oil drain goes directly into oil pan via a one-way valve.
Key to all this is the staggered baffle down in the block under the oil filler tower.
SS Filter...
SS Filter...
#67
Have you seen the stainless steel filter element for the Provent? Works perfectly on the GT racecar.
SS Filter...
SS Filter...
