928 Forum 1978-1995
Sponsored by: 928 Specialists
Belt tension warning light??
Old 07-09-2012 | 02:07 AM
Landseer's Avatar
Landseer
Light was added for 85 ROW 16V, as well as for the new 32V cars.
Seems there is a good chance its interference, so I'd assume it.
Disassemble and go through it, piece by piece.
Takes a weekend and a few tools. Prerequisite of ownership, well, usership. Simplest thing to work on, car-wise, on his long laundry list of special high end cars.
Old 07-09-2012 | 05:48 AM
Podguy's Avatar
Podguy
Originally Posted by Hilton
Under hard acceleration is when the warning light usually triggers for a belt that is marginally too low on tension. Get it sorted by someone who knows 928's.
If the problem was electrical, then it would happen at low rpm's too (just not for 3 minutes after starting the car - the warning is delayed that much by the car)
No this is not true. My belt light came on under the same conditions. It turned out to be an electrical issue with the timing belt circuit. A little crimping fixed it
Old 07-09-2012 | 05:51 AM
Podguy's Avatar
Podguy
The 85 Euro S is an interference engine. Go figure.
Old 07-09-2012 | 11:35 AM
Hilton's Avatar
Hilton
Yes - highest factory-rated compression of all the 928's on the 85-86 Euro 4.7L at 10.4:1
The later '84 euros are also the high compression interference motor too - there was a mid-year piston change. a search of rennlist will bring up the engine numbers Porsche documented for the change for the auto and manual engine number series'
From 80 to early '84 the K-jet "Euro" 4.7L 928S are non-interference as long as there isn't significant carbon buildup.
Old 07-09-2012 | 11:46 AM
jeff spahn's Avatar
jeff spahn
The OP doesn't seem to really know what the timing belt is or what problems breaking one can cause based on the brevity of his post.
Quick Reply: Belt tension warning light??
