Sluggish at low speeds
Blumaxx is running sluggishly lately, primarily at lower speeds. Idle revs are fine, if just a tad high at 800 rpm. Oil pressure is good. The car feels sluggish when pulling out from a stop, at a light or intersection or whatever. Once moving, it feels strong. I don't hear any missing or anthing like that. It's just when I start out, it doesn't feel like it wants to jump like it did previously.
The gas is good. I've run a couple of tanks, and also put in Techron.
Any thoughts? Plug wires/plugs? Other things?
My grounds are all good. They're clean. I don't think it's a vacume leak either.
Plug wires are old. Probably time for a complete tune up in any event.
My grounds are all good. They're clean. I don't think it's a vacume leak either.[/QUOTE]
Ed,
Pull a couple plug wires, unscrew the ends and take a looksee. You might find the terminals don't want to unscrew and you may find the screw terminals will want to break off easy. So only do this when you are prepared for the to easily break.
Ed,
Sounds like the car is running rich off idle.
Could be due to a mechanical issue with the throttle body. I would check your throttle linkage and cable. Slop in the linkage can make the car feel weak and non responsive.
what plugs do most recommend?
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
Wow I am dealing with a hard bucking or skipping during acceleration as well. I just put a thread up. I may go change the plugs for the hell of it and see what happens.
As is often the case, I like Brutus' inclination. Check the timing and check the vacuum line to the advance module.
With fuel- depends on degree of severity but too rich can give a fuel odor and/or black smoke out the tailpipe..and a stumble perhaps down low. Too lean can bring the detonation but that can be tough to hear if not severe.
IIRC 78 does not have a vacuum enrichment signal.
thought the CIS control press reg/warm up reg had a vacuum line to adjust mixture under load ..."IIRC 78 does not have a vacuum enrichment signal." But I am still betting on a timing problem given the symptoms.
Running strong now. Replaced the plugs with Bosch platinum, plug wires with Beru, new rotor, cleaned everything up inside of the distributor cap, new air filter, running good now.
Old wires were the originals, and maybe the plugs too? Anyway, they were not black coated, or too toasted. Car idles perfectly at 750 rpm. Accelerates nice even at low speeds again, and pulls like a freight train in all ranges.
Thanks to Rick (Wyatt's ride) for coming by on short notice and lending a hand
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
