ABS warning light
Team Owner
unplug the abs brain and you can test the speed sensor using an ohm meter. it takes a few minutes. there is a write up on pelican parts forum.
also, flush the brakes, especially the front passenger side. air in the lines will cause either immediate abs light or intermittent, depend on the amt of air trapped. i had this and it was a pain to finally figure out this was the cause.
After all that time, I finally found the problem
It was a broken female connector in the 4-pin plug near the CEB. So there was no voltage (12V) at pin 10 on the ABS Pump 12-pin plug.
well done Luc...........always gratifying to find a problem thats been nagging for a while.
Can you go and test the car or is there to much winter weather?
