ABS warning light
ABS warning light
I have the ABS warning that comes on as soon as I start the car so most likely cause is the ABS relay on the CE Panel. I bypass the relay by plugging two spade terminals into the slots on the relay board, that correspond to pins 30-87, no change.
So the next step is to change the 2 relays on the pump ??
Not necessarily. When I had ABS light on ignition turned out to just be ABS fuse. I had moved the controller when working in footwell without disconnecting battery, so must have caused a spike when I plugged it back in. All fine with fuse replaced
Just had this very problem on my '87 auto; relay and fuse checked out fine on the fuse panel, but warning light still on. Pulled the two relays on the ABS pump (they looked perfect even after 25 years) they also checked out fine, put them back and....all is well, no more warning light. Hope yours is as easy a fix.
After replacing the both relays on the pump, the abs warning light still on as soon as I start the car.
Next step is to check/replace the pump or the brain ? Can the pump or the brain can be repair? Or I need to change them ?
Inventor
If it happens as soon as you start the car, vs. after the system-check at 4 mph, then it is likely the ABS relay.
The relay has a big diode in it which goes bad. The relay is surprisingly expensive, BTW.
You may get lucky with a used one, but it may also go bad in short order.
Almost all of my S3s needed one when I bought the car, or soon after.
Luc-could just be bad sensors at any of the 4 corners. Before jumping to the pump-you should check each hub. Also check the grounds on the front facing side of the battery compartment under the plastic cover. Those connect to the ABS and if there is a ground issue there, you'll get the warning.
