Center console bolts
Does anyone know the part number (or just the specs) for the three center console bolts/screws which go in vertically under the dash (2 on the left and 1 on the right). ? After exhaustive search of old posts and the parts manual, I can't seem to find it. Apparently a PO removed them all, so I have no sample to go by. I'm not talking about the two behind the vent diffuser (part 14 in the dash pic in the parts manual) or the one in the glove box.
Thanks,
Matt
Thanks,
Matt
IIRC, the two in the vent diffuser are M5 bolts. The one from the side of the glovebox (you have to remove the glovebox to get at it) is a screw with an 8mm hex head.
edit: Just checked PET.
The two pointing upwards in the maincentre vent are M5x16mm bolts - part no. 900 075 145 02
The screw from the side is a hex-headed 4,8 x 16mm (10 gauge screw, 16mm long) - part no 900 187 018 02
Thanks, but those are the ones shown in PET that I know already. I am asking about the three other bolt holes under the console at the same level and plane as the bottom of the glove compartment door . Also, when I had the console apart yesterday, I found a fourth hole just behind the lower left corner of the glove box door. That one looks like it has a speed nut on it, and is smaller than the other three.
-Matt
-Matt
