Power steering hose question
Hello all
Anyone know what PSI rating a replacment PS hose should be minimum?
Cheers
John
Cheers
John
Depends if you're talking about the return line, which is low pressure, or the high pressure line from pump to rack.
Confess I don't know precise spec of either!
John : Have a look at our resident guru/write guy Dwayne: http://www.dwaynesgarage.norcal928.org/PS%20Hose.htm
The writeup is also in this forum...just search (top right).
If you are in the UK, just get Pirtek to make you new lines. Their hose exceeds the Porsche requirements by a wide margin. Both my 928s have them and are wroking fine. Get them to fit swivel fittings to make it easier to refit the hoses. The RHD path is quite convoluted as the hoses have to follow the cross member across the engine bay
Ken
80 928 S
5 Speed
UK
Hi Guys
Would i need to take the old pipes in for them too make them up or do they already hava pipes ready and made?
Cheers
Cheers
Ken
80 928 S
5 Speed
UK
Thanks will get them off and go to Pirtek
.., take the pipes with you, try and remember the orientation of which way they go, I only had the one to do ( the awkward one) and the lad was able to fit the swivels correspondingly . Once refitted at either end, you leave the swivels slack and then are able to move the pipe into a satisfactory position and tighten up.
Ken
80 928 S
5 Speed
UK
Ken
80 928 S
5 Speed
UK
