tweeter question
Does someone know the part number for the mount for the tweeter on the door for an 89 928? It looks like the tweeter is placed on a plastic mount that is screwed to the door and then the speaker grill is placed over the mount.
I checked PET and all I see is the speaker grill, screws, and the tweeter.
Or do you get the mount with the speaker grill?
Hoping someone here knows the part number for the mount.
Thanks!
Thanks!
I think it's part of the tweeter.
FWIW, I recently repaired this plate in my car, which was basically crumbled and broken around all four mounting holes. I used Loctite Plastic Bonder Epoxy and some aluminum (furnace) backing tape to fill in the broken areas, then ground/filed/sanded it down once it had set overnight, and drilled new holes.
