PSD pump question
My '89 S4 is fitted with a limited slip differential. Reading the Ott/Veninger document on flushing, they reference that it is not used on LSD's prior to 1990. Just confirming that this correct?
Originally Posted by Dave928S
They both did such a great job that it was declared a draw ... and they were promoted to work as a team on perfecting engine breathing and oiling.
Received 1,615 Likes
The wiring diagrams for '89 show the wiring for PSD (M221). I have direct first-hand experience that the dash harness, abs harness, and instrument cluster firmware are "PSD ready." I assumed that since there was wiring and an option code that it was an option.
So you are saying that PSD was NOT an option in '89?
WP0JB0928KS860061
WP0ZZZ92ZKS840061
WP0ZZZ92ZKS840062
WP0ZZZ92ZKS840063
WP0ZZZ92ZKS840064
WP0ZZZ92ZKS840065
WP0ZZZ92ZKS840066
WP0ZZZ92ZKS840067
WP0ZZZ92ZKS840068
WP0ZZZ92ZKS840069
WP0ZZZ92ZKS840071
So it looks like factory did just one US model and 10 German cars with it. All are very early cars which means they were likely factory demonstrators or one could even call them prototypes for '89 MY production. For some reason Porsche decided to leave PSD out for a year. Maybe they thought it wasn't ready yet.
Same thing was done with ABS option on '82 MY. Four ROW cars have M593 option listed and they are earliest two 4.5L and 4.7L made.
WP0ZZZ92ZCS800051
WP0ZZZ92ZCS800052
WP0ZZZ92ZCS840051
WP0ZZZ92ZCS840052
ABS made comeback two years later on 4.7L ROW models.
Dave,
I can confirm that the PSD was designed into the 1989 Digital Instrument Cluster, as was the air bags and as we know some 1989 manufactured cars were actually built as 1990 models. This Instrument cluster was a K25 model and was manufactured in Dec 1989.
When I was chasing a fault in my 1990, I installed a loan 1989 digital instrument cluster manufactured in July 98 into my car and the PSD was operational, as it was also a K25 model. I have now fitted a later K29 model in with original set up in the German language, which I believe was the latest model and all functions on my 1990 are still fully operational, however I believe that the Diagnostics for the Instrument Cluster has been change some what to the original. I still have to check this out. I have changed the language to English, but the Stop Light indication is in German, but no problems. now need to reset the odometer to the correct kilometres and trace the fault in my old #2 PCB, if possible.
To OP:
