electric tape question-high temp
The trick is tension. The tighter you stretch it, the better it works. Tie the ends off with spot-tie so you can forget about it. The end always tries to come loose. Just tie it off.
That's all I've used is the black silicon tape when I need protection. I used nearly 100 feet of it when I fabricated my alt-starter-posts wire harness. I purchased large roll of the stuff from Pegasus Racing. For my thermal protection I used about 100 feet of 2 inch wide fiberglass tape from an aviation supplier. This material specifically for thermal protection. I was really very happy with the result. Did this about 2 years ago and no degradation of the harness. Excellent thermal and water/engine gunk protection.
