ICV Flow 85 US
Does the ICV valve flow from the bottom of the throttle body,up into the base of the center intake tube Pulling extra air into engine when needed?
Could an accumulation of excessive oil in the elbow stop the flow of this air.
Oh and no, don't think it would stop air flow, just help it get dirty and make it stick.
I'm not sure where people have come up with this notion that oil in the intake can cause detonation when it goes into the cylinder. Every engine I've seen that has had an oil consumption issue tends to not want to ignite. If anything, it should have an affect similar to water injection which which absorbs excess heat and prevents detonation. If detonation were an issue, there would be a lot of pissed off '85/'86 owners frantically searching for replacement engines.
