Clutch problems...please advise...
Can someone please advise me as to what areas I should be looking at to solve the problem? I've tried bleeding the clutch hydraulics as well...it acts as though there's a check valve in there somewhere, as the power bleeder barely passes fluid into the system, even under ten PSI.(BTW, for those contemplating a clutch replacement, GearWrench's new pivoting head ratchet-type box wrench is the bomb for those upper TT bolts on the inside of the TT. Lock the head to break loose the bolts, and then unlock it to use the wrench in a piston motion in conjunction with the ratcheting feature of the wrench to back the bolts out once they're loose.)
Also adjust the intermediate plate for proper release and your problem will likely go away.
if original you should replace the whole system including the flex hose,
do a search for modifying the master cylinder,
you could remove the old piston and spring and swap over the seal then fit to the new MC , the flex hose swell over time this may be the issue, the slaves will leak,
the pushrod adjuster at the MC may need to be adjusted you should see about 4Mm of pedal travel before the rod moves the piston
Still struggling with it, going to try power bleeding from the slave end before replacing master...if that becomes necessary, is it necessary to bench bleed master? Any other tips pertaining to replacing the master?
Thanks in advance, you folks are great.
Go under dash to clutch pedal,
You will see a rod which connects the pedal to the master.
It has a 13mm nut on it, back this off and then thread the rod more into the block.
Do this until there is a tiny bit of freeplay in the rod to master.
To adjust the int plate,
Drop the lower bell housing cover (what the slave bolts to),
Then locate the 3 adjustment tabs on the intermediate plate, adj towards the engine leaving about a 1mm gap.
Pry the release arm back with a rachet strap and turn crank with a 27mm socket on front of crank to access all 3.
Adjust these down with as little tolerance as required to allow free movement of the discs ( you can reach up and turn the stub shaft by hand, or rotate engine and ensure discs don't turn.
Once this is done report back.
You needn't do anything to the rest of the system!!!
Many thanks to all; the clutch works better than it ever has, and the trans shifts like velvet (it was a little balky before, especially when cold), which leads me to suspect it needed the adjustment all along.
Glad you got your problem fixed.
