928 Forum 1978-1995
Sponsored by: 928 Specialists
Cam plug seals (hockey Pucks) : Possible to replace without removing engine?
Old 06-26-2012, 01:27 PM
thezonster
thezonster's Avatar
I was able to get the outboard passenger side plug easily from under the car.
Old 06-26-2012, 05:31 PM
dcrasta
dcrasta's Avatar
I haven't done these yet .. I have the parts, but once I rebuilt the transmission lines the smoking stopped, and the leak is more of a weep from one side. Once it goes back up in the air for the MotorMounts and oil pan I will try to tackle this!
Glad to see others have .
Old 09-30-2012, 11:43 AM
Jchiodi
Jchiodi's Avatar
Doing this now, what a bitch. Too many things in the way!!! The dremel was a great idea, used it!
But couldn't get it in on the inboard rear drivers side. Went low tech. Used a serrated kitchen knife to saw through the old retainer. Worked very well. Then tapped on the sawed plastic with a screwdriver and soft mallet. Broke off the edges and finally could get a wrench on it.
BTW, got to all of them from the top, I did have the valve covers off but probably didn't need to.
And although I have all kinds of offset wrenches and small sockets, ended up using plain combo wrenches.
Now to put the new ones back on. oh boy
jc
Old 09-30-2012, 12:53 PM
Landseer
Landseer's Avatar
^^ that's some innovation! I'll remember that!
Old 10-01-2012, 01:14 PM
dcrasta
dcrasta's Avatar
Glad for the update. I have yet to tackle this job for fear of having a car down and my backup (Jeep) is getting front suspension work (Ball joints) so this will have to wait. Post pics if possible
Old 10-01-2012, 03:07 PM
JHowell37
JHowell37's Avatar
Again, you're welcome to come over and do it at my place. I've done this before.
Old 10-02-2012, 09:15 AM
Jchiodi
Jchiodi's Avatar
UPDATE- These went in a lot easier than I thought they would...
One thing that helped quite a bit was to replace the bolts with ones that were slightly longer and adding a two washers, one a locking one. I was able to push these in, mostly with a lot of finger pressure, and if one was not quite in, a slight push with a breaker bar snugged them in tight! Worked with a regular combo wrench.
I am hoping I won't get that burning oil smell now, just got to back to the TB/WP work
Old 10-02-2012, 11:05 AM
dcrasta
dcrasta's Avatar
Hey man. Are you going to the frenzy ? I definitely need your advise on some things. Will call over the weekend!
(I bring beer and barbacue!)
Quick Reply: Cam plug seals (hockey Pucks) : Possible to replace without removing engine?
