928 Forum 1978-1995
Sponsored by: 928 Specialists
Piston Ring Compressor
Old 01-29-2016, 05:49 PM
  #31
mark kibort
mark kibort's Avatar
i use that adjustable one as well. you do have to be very careful though. never broken or scratched anything yet, but im very careful with it.
Old 01-30-2016, 07:25 AM
  #32
The Deputy
The Deputy's Avatar
The adjustable one is okay, and can be used with great success...if used properly. After time though, they do tend to wear out, especally the little flared edges that are suppose to rest on the block surface. Once they get worn or damaged...they can make for difficult times.
The Wisco sleeves are the way to go.
Yes, covering the rod studs with 3/8 fuel line...helps keep you from boogering things up. Cut the fuel line about four inches long and position the fuel line on the stud so the natural curl of the fuel line faces outward...this will hold the rod away from the bore as you put things together.
Go slow, and don't rush, force or cut corners...and use plenty of lube...and you will be fine.
Brian.
Old 01-30-2016, 07:42 AM
  #33
Strosek Ultra
Strosek Ultra's Avatar
Brian.
The Wiseco type sleeves are easy to fabricate if you have access to a lathe.
Åke
Old 01-30-2016, 12:42 PM
  #34
Jerry Feather
Jerry Feather's Avatar
Originally Posted by Daniel5691
Resurrecting a thread here...
QUESTION: What is the best way/location to measure the bore for selecting the correct compressor?
Thanks !
Dan
Dan, I think I would be inclined to measure the diameter of the piston just below the bottom ring.
Old 01-30-2016, 12:45 PM
  #35
Jerry Feather
Åke
I have a lathe, but wonder what they are made of. I'll probably do this when I get to my stroker which is also bored to 105.5mm. Actually it has steel cylinders that are half sleeves and half full steel cylinder.
Old 01-30-2016, 01:02 PM
  #36
Daniel5691
Daniel5691's Avatar
Thanks Jerry, will do.
Dan
Old 01-30-2016, 04:08 PM
  #37
Kevin in Atlanta
Kevin in Atlanta's Avatar
I used the adjustable, too. I found I was more successful if I had the cylinder perpendicular to the floor. Somehow this let me tap the adjustable ring compressor flat to the head. I use the wooden handle of a rubber mallet to tap the piston.
Quick Reply: Piston Ring Compressor
