JMO, but shouldn't hood insulation be non flame-able!!!! Yes another 928 fire
#31
Under normal circumstances even the exhaust manifolds aren't that hot on a stock 928 idling.
Under hard use (think track duty), with a tuned car you will possibly see this temp in the manifolds.
Plus I would like for you to show me it actually auto ignite at that temp.
It will instantly turn into vapor which is much more volitile. But I doubt it would auto ignite every time. On top of that additives will effect this as will octane rating.
#33
Lets not start qualifying the _entirely_ possible with "it was only at idle" cuz idling commonly happens after driving..and then that true..it has to be right conditions..but hey, it happens every day.
Fact is..gas and hot running engines are dangerous..it can happen...and somewhere in a vapor cloud in an open area near a spill..it'll be the right conditions, just needs heat. Or as said, a spark.
#34
Captain Obvious
Super User
Super User
