928 Forum 1978-1995
Sponsored by: 928 Specialists
Another hello
Old May 27, 2012 | 07:33 PM
karl ruiter's Avatar
karl ruiter
Most folks get good results by tossing the in tank pump and replacing it with a strainer.
Old May 28, 2012 | 10:03 AM
bran3b's Avatar
bran3b
Thanks for the tip, I will give the strainer a shot.
Old May 28, 2012 | 11:37 AM
Dave928S's Avatar
Dave928S
The strainer is a good option but, out of interest, what's wrong with the intank pump? There are a few simple things that go wrong with them that are fixable.
Old May 28, 2012 | 02:12 PM
bran3b's Avatar
bran3b
It seems to have seized but if it is serviceable then I will take a look at that first. I am sure that the short hoses are shot. I will dig into it and report back shortly.
Old May 28, 2012 | 06:52 PM
bran3b's Avatar
bran3b
Dave, that did it. I pulled the pump apart and replaced the short hose section. I checked everyone else, re-assembled and Katherine car fired up. Thanks to everyone for your help. Now to tackle the leaking exhaust and several minor issues.
Old May 28, 2012 | 08:18 PM
Dave928S's Avatar
Dave928S
Good result .... depends on what type of hose you used, but it's worth checking every once in a while to make sure the hose is still OK. You know how to do it now, so that'll be easy.
My GTS had a hose that was marginal, which I replaced with reinforced hose, and the soldered joints on the wires weren't properly done and I had a dry joint .... fixed that some time back and solved my intermittent no start.
BTW ... Welcome! ... and keep us all posted on your problems and progress.
