Home made PS feed line
late modle pump, early tank.... hummmm..... can't run a normal hose due to the angles, and local hose shop cant make rubber lines with bends that can handle oil... so this will have to due till i can figure out a cleaner looking one...
they rebuilt my pressure line as well. but any shop in town i have checked does not bend metal, only reuses your ends etc... but thats ok, i went and got the AN fittings i need. ill have that hobo job replaced tonight.
I just did that molded hose as it began to leak from cracks at the first 90 degree bend below the tank. Had I seen this post...
Well I have about 20k until the TB/WP/seals... Will definitely go braided on this hose. With so many contortions on this thin hose it will always degrade earlier relative to its linear brethren.
