She Runs! Oh wait... no she doesn't
1982 928 w/ competition package 5spd black on black w/ sport seats
79k on body, 12k on rebuilt 4.5L
hasn't been driven in a couple years, but it hasn't been sitting either, it was running last year, but was taken apart for some maintenance by the previous owner.
I traded one of my cars for it without it running, so here i am now... trying to get it running.
here she is, my other cars in the background. the opel is my dads.
anything look amiss back here for getting it to run? there's no carbon canister hooked up, would that cause it not to run?
what does this plug go to?
compression numbers... cyl #8 seems to be lacking, might have some build up on the valves, i'll retest after she is running
engine bay shot, anything look amiss for it not to run?
sitting purty in the garage.
video of it starting... then stopping
i tested the compression and spark all around, all was working good. she cranks, and will start... for about 2 seconds.
I checked the wires and made sure the timing was on and all the cables were hooked up right.
Any other ideas on how to get it running? or does someone want to come give me a hand in Central NY? I'll give some money and beer
Archive Gatekeeper
Between pics 2 and 3 I see 3 disconnected 2-pin injector-type plugs. I don't know anything about 16V cars but I'd have to guess that they should be attached to things...
Experienced opinions will be forthcoming shortly.
oh woops, i connected those when i tried to start it lol.
actually though, while i was doing the compression check, i disconnected those wires and it still wanted to fire up... residual fuel?
Nice Audi Quattro Coupes.
You might also have some sort of fuel leak (or evaporation potential) depending on how it was disconnected.
Sounds like your injectors aren't really working. Probably starting on the cold start valve and then running out of fuel after a couple of seconds. Check your fuel injection relay.
Another note to Frosty: Be careful with those AMP style plugs. They're probably pretty brittle by this point.
Ok one other thing to check that messed me up a couple of times. Generally when a car has set the battery is removed and charged. There are two nuts on the battery terminal. One tightens the battery terminal to the positive post. The secondary connection connects two thick red wires to the positive terminal. If the nut holding these wires to the terminal are loose the car will act normal and crank over, but these wires feed the computer. A loose connection can be intermittent with the car starting sometimes and not others. Clean and check this terminal.
Good luck with the car. Oh put some oil in the low cylinder and it will come up to spec.
Have you checked fuel pressure? Injectors ok? Does your fuel pump run constant in ign on, eng off?
when i turn the ignition to on, now that i think about it, i don't think i heard the fuel pump turn on, should i? Obviously it's getting fuel though cause all the plugs were wet and smelled of gas. will the cold start cause this?
I'll have to look up how to check how the fuel pump is putting out during on-start-off
Plugs, wires, distributor cap?
thanks, definitely one of my favorites
Carbon canister system is connected to a couple of vacuum hose, so these may be wide open. If you look up at the underside of the hood when open you should see a vacuum diagram which will help you trace them down.
So i don't think that's the issue
I'll try a "2 relay jumper wire trick" search and see what it comes up with
no, early us cars can be 4.5 or 4.7 im only familiar with the euro spec injection these type is basically mechanical little or no electrics it has a big 8 pipe fuel distrubitor at the back of the engine under the air box.
