1981 Porsche 928 Climate control wiring harness question / wire color order
I have searched around the forums and I'm not finding exactly what I am looking for and hope someone might be able to assist me.
I removed the climate control unit in hopes that I could possibly clean the board to possibly stop the buzzing noise when the unit is turned off and maybe get the A/C working.
When I pulled the wiring harness on the left side of the unit (next to the **** to control the fan speed) the top of the harness block came out and all of the wires fell out of the harness. I don't know what order they are supposed to be in. The unit has 1,2,3,4,5 listed on the climate control system but there are two red wires (one with a black stripe) and the other three are white. One with that is plain white, one with a blue stripe, and one with a green stripe.
Does anyone know which order these wires are placed back in to the harness?
1 - white
2 - white/green
3 - white/blue
4 - red/black
5 - red/white
Your bottom picture looks like a red/black & red/white wires.
Your text however says a red and a red/black wire.
The above legend is from the Current Flow Diagram, Track 5, page 97-103 WSM
Good Luck with the job.
2 - white/green
3 - white/blue
4 - red/black
5 - red/white
1 - white
2 - white/green
3 - white/blue
4 - red/black
5 - red/white
2 - white/green
3 - white/blue
4 - red/black
5 - red/white
Rennlist Site Sponsor
The buzzing may well be vacuum, rather than electrical.
With the engine running and the buzzing audible, unplug the small black/blue drum-shaped check valve from the vacuum brake booster. If that is the source of the buzzing, you have a vacuum actuator which has failed.
If you go to our web site, then tips & links, then Wally's World, then the HVAC section, you will find info that will tell you how to test the vacuum actuators.
