928 Forum 1978-1995
Sponsored by: 928 Specialists
H-5 Headlights
Old Apr 7, 2012 | 12:26 PM
jheis's Avatar
jheis
Default H-5 Headlights
Nice pair of H-5 headlights on ebay
http://www.ebay.com/itm/200740798550...S:1123&vxp=mtr
Old Apr 7, 2012 | 01:12 PM
GlenL's Avatar
GlenL
Thanks.
I want these!
http://www.ebay.com/itm/130643292094...84.m1423.l2649
Old Apr 7, 2012 | 03:24 PM
danglerb's Avatar
danglerb
Alan's summary from a post on Pelican.
Subjective Ratings:
Sealed Beam .... 2/10
8" H5 ............... 6/10
7" H4 ............... 8/10
8" H4 ............. 10/10
Old Apr 7, 2012 | 03:33 PM
SanDiego928's Avatar
SanDiego928
Well, better than what I got. Need to change connector on my car I believe. Hmmmmm
Old Apr 8, 2012 | 03:43 AM
jheis's Avatar
jheis
For an early car, you can buy the 9004 plugs and crimp on male spades and just plug them into the original sealed beam sockets - or you can cut off the sealed beam sockets and splice the 9004 plugs onto your wiring harness. It's one harness for the whole front of the car though, so you may want to think twice before cutting things off.... It's just three wires to connect either way.
James
Old Apr 8, 2012 | 04:34 AM
Nicole's Avatar
Nicole
Cottage Industry Sponsor
Subjective Ratings:
I've had a pair of 8" H4s in my garage for more than a year, but I'm a bit scared of changing the connectors on my factory wiring harness.
Does anybody know, if there is an adapter plug or wire that I could use instead?
Old Apr 8, 2012 | 05:21 AM
Bill Ball's Avatar
Bill Ball
Under the Lift
Hi Nicole. Here's something....
http://www.pelicanparts.com/cgi-bin/...H%34%2C%20each
Old Apr 8, 2012 | 10:59 AM
Alan's Avatar
Alan
Electron Wrangler
I have a feeling that is just an H4 socket...?
http://forums.pelicanparts.com/porsc...sion-plug.html
However - if you also buy one of these per side:
http://www.rallylights.com/detail.aspx?ID=1409
You can make up your own plug & play adapter
Alan
Old Apr 8, 2012 | 03:36 PM
Bill Ball's Avatar
Bill Ball
Under the Lift
Yeah, it appears the Pelican part may be nothing more than an H4 plug without wires. Confusing advertising. Sorry about that. What you need is a male H5 (9004, HB1) plug and wire it to a female H4 (9003) plug to make an adapter. That's what Alan is suggesting. You can buy H4 plugs already made up with wires in any autoparts store and splice that to male H5. This place sells them pre-wired.
http://autolumination.com/connectors.htm
Look down the page at "Headlight Pigtail Socket Receptacles 9" Long - 16 Gauge Wire Leads"
Old Apr 8, 2012 | 04:43 PM
Nicole's Avatar
Nicole
Thanks, Bill and Alan! I ordered the pieces and hope we can make those work.
Old Apr 8, 2012 | 06:00 PM
White Lightnin''s Avatar
White Lightnin'
Veteran: Army
jheis... are you the one selling these?
