Freon capacity for '88 S4?
Does someone know how much freon an '88 S4 takes at capacity?
I'm trying to price out R12 cost compared to R134 as my compressor has seized and I need to re-do the AC.
Thanks,
Howard
Thanks,
Howard
Off the top of my head, I know the R134a capacities:
Without rear A/C: 860g
With rear A/C: 1030g
The amount is approximately 15% higher for R12.
Dan
'91 928GT S/C 475hp/460lb.ft
Dan
It should be measured in lb/pounds.
most auto systems start around 1 and 3/4 pounds and to around 3.0
it should be marked on the dryer but it is best to look it up.
To much and you will break the compressor
Just remembered that mine has a sight glass so yours may as well.
if you see bubbles in the glass it needs more. (go slow 1/4 at a time)
That's close enough, most all European cars are measured in oz . Oops.
Yes, most places should still be selling mineral oil, which is what you should use for R12 systems that have never had anything other than R12 in them.
Dan
Automatic GTS was converted to R134a in Germany by local dealer. Users manual has added sticker which state how much new style stuff should be used. Can't recall exact quantity but its clearly less than original R12. Something like 20% less. AFAIK all components are still same as before. Only seals were changed.
It should be measured in whatever units someone pleases. Porsche specifies it in grams. If you ask me, pounds and ounces is an idiotic and inaccurate way to measure mass.
Dan
Dan
But I Trained in Texas at LeTourneau and have 2 degrees up here. So ya everyone is idiotic.
You never just fill, you monitor pressure and temp, Dan.
Good info guys, thank you.
BTW my rear A/C is capped off, so just the front to worry about.
I know this has come up many times before, but what are the downsides to converting over to R134?
What is the current consensus on R12 vs R134?
I think the biggest down side would be the cost of converting.
R134 dose not have as low a boiling point as R12 but with the higher pressure 134 is run at some seem to feel the cooling is close to the same.
In most vehicles I can get the 134/AC down to 38-40F at the center vent, it depends on the humidity and temp of the day.
Dichlorodifluoromethane (R-12) is harmful to the ozone and so has been banned in most places.
http://en.wikipedia.org/wiki/Dichlorodifluoromethane
R12
1978-1979
R12, 950 grams or 33.5 ounces
1980 - June 1988
Revised Factory recommendation,
Single evaporator systems R12, 1050 grams or 37 ounces
Dual evaporator systems R12, 1200 grams or 42.3 ounces
July 1988 - 1992
Single evaporator systems R12, 950 grams or 37 ounces
Dual evaporator systems R12, 1150 grams or 40.5 ounces
*before you attempt to charge using refrigerant weights
stated above, always check in the engine compartment for
the factory R12 sticker, and verify the charge using an
R12 Pressures and Temperatures Chart
R134a
1978-1982
R134a, estimated 807 grams or 28.5 ounces
1983-1992
as per TB, 9501, 12/19/1995
Single evaporator systems R134a, 860 grams or 30 ounces
Dual evaporator systems R134a, 1030 grams or 36 ounces
1993 onward
Original Factory recommendation
Dual evaporator systems R134a, 1050 grams or 37 ounces
the factory R12 sticker, or an R134a retrofit sticker,
and verify the charge using an R134a Pressures and Temperatures Chart
1978-1979
1980 - June 1988
July 1988 - 1992
R134a
1978-1982
1983-1992
1993 onward
