sometimes the best things are free
All I can say is out of all the things I've done to the shark cleaning the ground points and CE panel made the single biggest difference in how the car runs.
I had a little of a rough idle and now its gone and I can feel the change in power as well. If you've been holding off it's time to get off the fence, glad I did.
Next thing I do after that is get rid of any of the aluminum fuses in the pannel. On the OB cars this causes most of the electrical problems, then lube up the fuse olders with super lube to keep then from corroding further. That usually cures 98% of the problems I ever had.
