928 Forum 1978-1995
Sponsored by: 928 Specialists
Valve tools
Old Mar 27, 2012 | 10:25 AM
dr bob's Avatar
dr bob
Chronic Tool Dropper
Originally Posted by Podguy
Dr Bob,
Thanks for the advice. Of course the first order of business is to measure the valve guides.
You must be better with a reemer. I always found it to be a bit time consuming.
Doubt if I'm any better. Challenge is usually around having the correct reamer for a worn stem. Stems measure tulipped, reamers are hopefully straight. Leads to a less than ideal fit when valves are reused.
I have a big crossbar-style handle for the reamers. Easier than a T style.
Old Mar 27, 2012 | 11:27 AM
fraggle's Avatar
fraggle
NoVA, PA and MD folks,
I had a guy deck my heads, grind all 32 seats and valves and reinstall everything with new valve guide seals for $225. That was two years ago and car is still running strong. I'm not sure if he's still in the hobby but I can check if anyone nearby needs work done.
Old Mar 28, 2012 | 04:12 AM
Podguy's Avatar
Podguy
When I get to lapping the valves I was thinking one of these tools might come in handy
