need an amp that's 18cm wide or less (SOLVED)
Well I got a good deal on an Alpine sub, and Alpine amp. Unfortunatly the amp won't fit. The sub fits perfectly in the tire well. I have 18.5 cm of clearance on the left for an amp.
I'm going to try the pioneer 7500, it's 20cm but may fit in there on an angle.
I got a cash desk, but I know the owner and he already new it might not fit.
I have searched but everything I find is 20-25 cm, nothing close to 18 cm That's 7" for you yanks.
Any ideas?
Any ideas?
Do you want an amp just for driving the sub? I've got a Zapco Studio 100x subwoofer amp, 6" x 10" x 2.3" approx, L+R preamp in (adjustable gain), adjustable crossover, 100w into 4 ohms (200w into 8 ohms). Manual is here.
Send me a PM if you think this would suit your needs.
Cheers, Jim
Cheers, Jim
Yes just for the sub. I will see what happens tomorrow, if the pioneer doesn't fit I will shoot you a PM.
That Rockford would be a perfect fit. Thanks for the info.
Why are you trying to re-invent the wheel? There is a nice amp right inside this enclosure.
![](https://sphotos.xx.fbcdn.net/hphotos-ash3/529902_3376352363527_1110883957_33253963_1502650930_n.jpg)
But it is quick sharp sub, very tight. Plus I can use it in my hatch if I decide to put the spare back in, and in my DD.
In that senario to amp will go inside the spare wheel.
And I saved some money.
I may do that, then I will be able to rotate it 90 degrees and put the amp in the front right side near were the harness for the gauges is.
I think the amp would heat up too much and also have a negative effect on the sound, plus the box has an internal port that runs around the inside, so probably not enough space.
The pioneer fit.
