LH22 EZF XDF TP5
Inventor
With TunerPro, you can cut and paste entire maps, so it could also be used to port the 16V maps to the LH721 chip, with O2 loop, and automatic idle control (this can be made ST friendly).
Inventor
Added LH527 16V XDF to zip.
Fixed LH WOT bypass (wrong one, before).
Added injector cutoff restore rpm (number of rpms below min in table).
Hi Porken,
My car is an 85 5-speed.
I have imported the EZ_422_32V bin and 928_LH22_32V_1.0 xdf file on Tunerpro 5 RT. I can view scalars and tables.
I have a Moates APU1 with G1 memory adapter and Innovate MTL-X I use for my 95 chevy van to do real time emulation, tuning and diagnostics on. To do that I also use an ADX file.
Do you know where I can find an adx file to use for the 928? I think I could use a Moates G2 adapter with everything I already have and that would enable me to use the same 27SF512 flash chips I use on my van.
I'm planning on buying one of your chips soon. I have an 87 fpr, x-pipe and high flow cats that I'll be installing soon. It sounds like your chip will work perfect for that. I would also like to install new cams and have my heads done by 928 motorsports. I would need a custom tune after that and an adx file would allow me to fine tune it.
Thanks,
Rob
Thanks,
Rob
Inventor
I need to update these definitions some day. These early ones are pretty good, but the ones I started on the LH2.3 and EZK are not up to date.
There is no diagnostic output from the early LH2.2 and EZ-F so an ADX (dashboard) definition isn't possible?
I think one could be made for the S4-up, but I don't know of anyone that's done it. The later diagnostic serial output was made for the Porsche diagnostic boxes. The protocol isn't universal like OBD I or II. (I've hacked a little bit of it to export some values, but I have not delved too deeply into it, yet.)
