928 Forum 1978-1995
Sponsored by: 928 Specialists
Replaceing Rear tires...
Old Mar 11, 2012 | 02:36 PM
Rick3452's Avatar
Rick3452
Default Replaceing Rear tires...
I currently have 255 R40 17 94 W on the rears. I have some room can I go one step wider?? Thanks....Rick
82 5 speed
Old Mar 11, 2012 | 03:40 PM
cfc928gt's Avatar
cfc928gt
What's the width of your rear wheels? When you say you have some room to go I assume you mean there's room between the tire sidewall and the fender lip?
Old Mar 11, 2012 | 03:48 PM
Adamant1971's Avatar
Adamant1971
Width and offset will help.
Old Mar 11, 2012 | 04:05 PM
Rick3452's Avatar
Rick3452
Is there an easy way to measure the width of the wheel without removing the tire?
Old Mar 11, 2012 | 07:40 PM
cfc928gt's Avatar
cfc928gt
Some factory wheels have the width and offset on each side of the valve stem. You could also try a dental mirror with a flashlight to look at the backside of the spokes to see if you can find the width.
Old Mar 11, 2012 | 08:40 PM
Randy V's Avatar
Randy V
25 Year Member
Depends on the type of wheel you have.
Old Mar 11, 2012 | 09:55 PM
VT928's Avatar
VT928
I have run a 295/35 17 Kumho's on the rear of my 1980 Euro S with no problems. The determining factors are wheel width and offset.
Paul M 1980 Euro S Red/Blk Lea
File Type: jpg
Old Mar 12, 2012 | 12:11 AM
joejoe's Avatar
joejoe
I am running 275/40/17 khumo on 9" et 50 rims. Might be 1/4" clearance, but I think it is a bit less, no rubbing however.
