Two Defrost switches? (Pics)
Well, I bought a 1984 Euro a couple weeks ago (!) and have started snooping around the car. It drives fine, however there are LOTS of electrical problems, but we'll get to those later.
But for now, I just have a random question as to why there appears to be two defrost switches in the car? There's the one on the dash in the upper right part of the gauge cluster, but then on the carpet just in front of the handbrake is a factory-looking rocker switch with the same defrost decal on it. Is this possibly for the mirrors?
There should be a round **** in front of the handbrake for the headlight adjustment (Euro only, removed for US cars). Possibly a volume control **** as well in the same general area. But as far as I know the only place for the defroster switch is in the instrument pod.
Team Owner
its possible someone has swapped the **** center cover for a defrost cover,
the centers pop out,
the **** you speak of sounds like the one used to open the hatch,
a picture would help here
Team Owner
ahh the mysterious trailer defroster switch..........
Team Owner
actually you need to remove the E brake cover and trace the wires to see where they go,
then post a picture.
The switch is not standard and might be a kill switch for instance.
The other 3 round switches are for speaker fader, headlight adjustment and hatch release
If you have an automatic it could be a kickdown switch. If the wires go back to the switch behind the pedal that would allow you to enable the kickdown switch manually.
That said, if it's a momentary switch probably not it.
Team Owner
I have never seen a switch like this a 928
