Anyone had leaking All Aluminium radiator issue?
Basic Site Sponsor
Basic Site Sponsor
Oh come now.
Are people _really_ being shamed for not paying $2000 for a new OEM radiator?
Yes, the full alum one is about a grand easy...but a corvette Z06 radiator is exactly $379.19. ($247.29 for the 6spd version)
And they don't complain..I tracked the living hell out of my Z06, and it -never- had a cooling problem.
Although I cooked a # of 6spd boxes...until I put in the auto rad and ran cooling lines to it.
Ya..mine leaks..so have others. But you're not gonna make me feel like a cheap SOB for paying 400% more than the OEM radiator is _worth_.
Same story with $500 motor mounts.
Although, I respect the opinions of others..they aint doing nothing wrong by making a different decision with their money.
But, in the meantime....a "long lasting core" is still over $800.00, if you are going to order 20 of them a year.
I could care less what decisions people make and what they pay for parts.
However, I'm a fanatic about quality and I do know what it takes to build/do high quality stuff.
I won't build/sell crap. There's plenty of others out there already doing that.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
Administrator - "Tyson"
Basic Sponsor
When you can get a factory two cooler Behr for $800 why would you ever consider an aluminium one. Just snagged another 10.
Even a Porsche supplied no cooler Behr is $814 and add an external cooler.
Listen to what Greg says.
Chronic Tool Dropper
The "racing" one-piece-welded all-aluminum radiators are probably great so long as you don't put them in a running street car. By it's nature, the radiator's going to have more heat on the top right side than on the bottom left side. There's no good way to manage cross-flow paths at different temperatures and coolant flow rates. The airflow temperature, flow and distribution all vary similarly with ambient conditions, speed and fan operation. Add in that "racing" radiators often have more rows of tubes and wider tanks to accommodate. Now, different areas of the radiator are expanding at different rates. So the radiator suffers from wierd and constantly changing expansion and torque stresses while the engine is running and the thermostat is open. Ultimately it's fatigue failure at a weakened joint that typically causes the leaks.
So there's no shame in using somewhat-flexible plastic tanks on radiators, with somewhat-pliable o-ringed joints to the cores. Maybe the one-piece radiator guys could step back and look at similar floating end tanks, as Todd has done, for their heavy-duty aluminum cores.
i have a small fin leak in my stocker, and i had ordered up a alum one and have yet to install it. I'm still trying to figure out what i want to do for fans. are the leaks people are getting from the alum welds? or cracked tubes?
Electron Wrangler
My C&R leaked after about a year - same symptoms - where core meets side tanks.
I had it cut apart - re-welded - and epoxied for good meaure - it has been fine since - but it sure wasn't cheap - either initially or for the repair.
It works well though - as you'd hope it would!
At the time I installed it (about 5-6 years ago) there were no Behr radiators to be had - and sitting on it for an ~4 week lead time (on my DD) was not an option.
Alan
Alan
Got one of the "Racing" all aluminium ones on my hand with only 6K miles (little over 2 years old) that has a leaking core, right where the core meets the end tank. About 4 rows are leaking, top driver side (overflow port corner), facing the engine. Everything indicates that it has to be a manufacturing defect as there are no signs of damage. Anyone had problems like this?
I'm using an off-the-shelf Big Block Chevy racing radiator: a few little welds to work with our mounts & it works great. No cooler, but with the race car I have a massive external cooler anyway. Under $200.
I didn't see any production numbers for 2011 Corvettes, but they made over 12,000 in 2010. I'm going to guess that if I was GM and had my very own radiator building plant, we could probably get the price down some....
Greg..you sell good stuff. I'll _never_ argue against that.
But Behr makes a billion radiators.
Radiators.
Porsche doesnt have a gold sealed unabtanium...radiator.
Same materials as everybody else's. A Radiator.
A kick *** hand built customer never fail cools like the sub arctic and supports 650Hp in the Sahara...ya..there's HUGE value in that. Undeniably.
But Behr..mass production, army ant productivity...radiators..plastic, some metal, some sealant..radiators.
Very basic design...radiators.
The Parts Whisperer
Seeing as these premature failures are across the board with all manufactures it makes me wonder what Behr does differently. Is it possible that they plate or coat their cores before assembly? We have seen first hand here lots of poorly maintained original radiators that still do not leak after 20 plus years.
The advent of the all aluminum radiators came about when the only option was the factory radiator at nearly $2k. Now that Roger and I have Behr units for less than the aftermarket, that has changed everything.
Basic Site Sponsor
Basic Site Sponsor
928 people can say whatever they want about the price of the Behr. They can bitch about the plastic side tanks and the "o-ring" seals. But what Mark is saying is true....how many other cars can you find that have 20 year old radiators still in them?
