Need 87 s4 Chip
When it was installed only thing that changed was Tim did the shark tune for it sorry I don't know the difference between the EZK and the LH. Only thing that was changed was the chip for the timing so i don't know which one I need. Will take what you have if it is the right one.
Cliff
Cliff
There are two computers in the S4: EZK is the ignition/spark computer and the LH is the fuel injection side. Typically, both would be tuned/customized so as to be "on the same page" (memory pun intended). I am no expert, however.
So, I think you would need a stock EZK chip and a stock LH chip to go back to stock, replacing the tuned chips in each computer. I wouldn't expect smooth & efficient running with a mismatched pair, especially if one was tuned for SC and the other was stock.
The EZK chip I have here is marked "2 227 355 334", so according to this thread:
https://rennlist.com/forums/928-foru...-and-year.html
I have a 91 S4 chip; although different, probably not substantively from the 87 chip.
I'm happy to sell the EZK chip for $25 shipped but I would recommend you find someone with an S4 LH chip to go with it, or contact Elektronik Repair or JDS Porsche to get a matched pair and forget about mine unless someone chimes in with an S4 LH chip they have lying around.
