While we're (Briefly) on the Topic of R12.....
#31
Be extremely cautious about converting your old R-12 system to R-134a. Frequently, the new R-134a refrigerant will not circulate the R-12 oil and you will burn up your compressor. The R-12 mineral oil has chlorine contaminants that will destroy the R-134a PAG or POE special oil. The only way to reliably convert from R-12 to R-134a is to remove the compressor and flush out all the old oil with the new type of oil; then replace the old Receiver-Dryer or Accumulator with a new one; then flush out all the lines, the evaporator, and the condensor with special cleaner then vacuum to a steady vacuum; and finally charge with 70-80%, (by weight) of the original R-12 weight, with R-134a; and expect poorer cooling ability. It is much easier to keep the old R-12 system running IMHO
#34
Rennlist Site Sponsor
Unfortunately, it is illegal to use it in the USA...
From the DuPont info:
"ISCEON® MO49Plus™ is also an HFC retrofit refrigerant for
R-12 in automotive air-conditioning systems. See the Retrofit
Guidelines for Automotive AC for more information."
"Note: ISCEON® MO49Plus™ is not available for automotive
air-conditioning in the U.S."
#35
#38
