928 Forum 1978-1995
Sponsored by: 928 Specialists
GTS Cam broke
Old 02-07-2012 | 04:27 PM
  #61
whatudrivin's Avatar
whatudrivin
Hey Richard here are the pictures that I took while we were on the side of the road. The first car in the picture is Sean's car.
Old 02-07-2012 | 04:53 PM
  #62
69gaugeman's Avatar
69gaugeman
Originally Posted by SeanR
Here's a closer look at the cam gear. Obviously the bolt has been loose in the past otherwise the key wouldn't be torqued like this. I find it odd though that the bolt had good torque on it when I checked it the other day. Makes me wonder if it was found loose like this in the past, re-torqued w/o a proper inspection. This is not due to a cam shaft defect.
There is a slight bit of rust, but not at any of the break points on the retainer. Just the mating surface between retainer and cam gear.
We can all speculate as to the cause, until I get the engine torn down we won't know for sure. There is a chance the parts are fine with the tensioner arms/bushings/belt/pump and Greg is correct about this gear/bolt.
The shiny sections on the cam itself is where the crack was for some time. It looks to me like the crack propagated from the inside diameter opposite of the key-way. There is also evidence of a crack at the root of the key-way that propagated radially around to the first crack.
Yes this is what I do for a living (Mechanical engineer)
Old 02-07-2012 | 05:21 PM
  #63
GregBBRD's Avatar
GregBBRD
Former Vendor
Yup.
That's the problem.
The bolt was slightly loose, allowing the pieces to work against each other. As I said, after the break occurs and the two broken pieces are separate, the broken off "nub" will rotate on the end of the remaining camshaft, until the "high spots" interfere. That will make the bolt tighter. The "shiny" area is actually where the two pieces rotated against each other, until the "high spots" grabbed and held everything in place.
Old 02-07-2012 | 09:42 PM
  #64
SeanR's Avatar
SeanR
Originally Posted by GregBBRD
Yup.
That's the problem.
I love this community.
The level of expertise we have here is just amazing. I bet there isn't a thing with these cars that someone else has not seen.
I'll be pulling the engine starting mid next week and I'll keep a running documentary on what's found and how the rebuild goes. As always, feel free to comment but don't get butthurt if your thoughts go unheeded.
Old 02-07-2012 | 09:57 PM
  #65
blown 87's Avatar
blown 87
Rest in Peace
Old 02-07-2012 | 10:35 PM
  #66
NoVector's Avatar
NoVector
For the tension light to keep coming on and going off, would it have been caused by the bolt loosening and causing slack and then catching itself and tightening back up? Or is that something unrelated like maybe the conti belt stretching?? No kidding, if it wasn't 10 degrees here, I'd be in the garage right now checking my cam gear bolts!
Old 02-07-2012 | 10:38 PM
  #67
Imo000's Avatar
Imo000
Captain Obvious
Super User
You are missing the concept, the bolt never "caught itself".
Old 02-07-2012 | 10:45 PM
  #68
NoVector's Avatar
NoVector
Okay, so I just re-read this again, then it was after the break "the broken off nub will rotate on the end of the remaining camshaft, until the "high spots" interfere. That will make the bolt tighter" So if that only explains the after the fact how the bolt got tight again when Sean checked it, what caused the light to go on and off? Was it not a loose bolt loosening and tightening??
Old 02-07-2012 | 11:02 PM
  #69
namasgt's Avatar
namasgt
The bolt was slightly loose the whole time, either from factory or from the last timing belt job, until the cam broke from accelerated fatigue due to the loose bolt. The previous mechanic could have loosened the bolt by accident during the last timing belt job.
A simple thorough inspection from the mechanics would have caught the problem and prevented this failure.
The bolt tightened back up after the failure happened like I explained on the last page.
Old 02-07-2012 | 11:27 PM
  #70
NoVector's Avatar
NoVector
So the loose bolt/cam was exaggerated during higher RPMs causing the belt sensor to trip. Got it--thanks.
Old 02-08-2012 | 12:06 AM
  #71
turbobooost's Avatar
turbobooost
Default Sorrrrrrrrry Rich !!
But now you will be forced to make the changes to make it REALLLLLLLLLLLLLLLLLY fast for THE STICK !!!! LOL..If I can do anything for you just let me know...
Old 02-08-2012 | 01:12 AM
  #72
danglerb's Avatar
danglerb
Belt sensor light could have just been flaky belt sensor meets conti belt and unrelated to the cam issues.
Old 02-08-2012 | 02:23 AM
  #73
GregBBRD's Avatar
GregBBRD
Former Vendor
Agreed.
Doubtful that the engine ran very long after the cam actually broke...just long enough for a bunch of valves to hit pistons.
Old 02-08-2012 | 07:07 AM
  #74
RKD in OKC's Avatar
RKD in OKC
Kinda waiting for Sean to check the condition of the passenger side before deciding the extent of how deep down the rabbit hole I can go.
Till then I'm bugging a LOT of people with questions. Think I'll start a thread.
Old 02-08-2012 | 11:26 AM
  #75
whatudrivin
Agreed.
You would be correct there. The car lost power then as the snap happened we heard a distinct grinding noise. It was the cam gear hitting the timing belt cover. Then the car died and we rolled to the side of the road. I wasn't sure what the grinding was because I expected to hear pinging or something like that. It didn't click till we saw the broken cam and the wear marks from it hitting the cover.
Quick Reply: GTS Cam broke
