bosch 044 pump whine - replaced with 87-88 fuel pump, whine gone...
#31
Supercharged
Some pumps were designed to suck fuel and some were not. The external pumps that were used with the internal pumps were not designed to "draw fuel". They will be noisy without the in tank pump feeding them.
So the answer is yes....if you use the correct part number for your vehicle (928 608 104 03).
If you were to use the pump for an '87-'88 vehicle (928 60 104 02), you can get away with not using the in-tank pump...although I have no idea why anyone would want to do this. Feeding fuel to the primary pump is a great idea.
The guys at Porsche and Bosch are fairly smart people. Just follow what they did and you can hardly go wrong.
BTW...Does your tank strap still have all the original foam insulation, or it is gone, like lots of these vehicles?
My 044 pump is slightly louder than the stock pump, but not much. The only time I ever heard it really whine was when the tank was almost empty... Oh and one time when I didn't have the cover installed right so it rattled against the cover - but that was super evident.
One other thought and a bit of a digression... I recall there was a period when there were some counterfeit 044 pumps being sold. Now, even wholesalers can get duped, so your normally reliable vendor could be unknowingly supplying counterfeit parts that just are not up to the task.
I used to work for a major parts supplier (TRW) and I remember we caught a company selling brakes made from our castings, but we didn't make them - so they were counterfeit. What we found out is that the casting supplier was selling our castings (and design) to some rouge Chinese company that then did the finishing machnng and assembly. Who knows if they used the same tolerances or safety protocols as we did. They may have been "functional" but I would have never put them on my car.
Just something to think about...
#32
Former Vendor
I disagree 200%! That in-tank pump is the biggest piece of crap ever sold by Porsche and built by Bosch. Now if you can GUARANTEE a pump that will last and supply enough fuel to not starve the 044 pump, I might reconsider my position. Until then, I will not waste any more time or money (or anyone else's) on that POS in-tank pump.
However, my view comes from reality and I'm not just sitting behind a computer, slinging out mere opinions.
I work on hundreds of 928s.
On Thursday, I had 6 GTS's in my shop, along with 6 other 928s.
I looked at my sales history and I replaced a grand total of 3 in-tank pumps, all of last year.
And the youngest of those cars is over 17 years old....
That doesn't make that pump the "biggest piece of crap ever sold by Porsche and built by Bosch", in my mind.
And I use the in-tank pump to feed every 044 pump that I install...and no one has ever said a single thing about them being noisy.
#33
Supercharged
It could be that your 044 pumps are genuine... Hence no whine. My guess is that the OP and you did not get the 044 pump from the same source.
By the way, it is not my opinion that the intank pump is a piece of crap. IT'S A FACT! I suggest you read this... Do not use the in-tank pump... EVER!
And just because the youngest intank pump you replaced was 17 years old doesn't mean it didn't fail years before you got your hands on it. I have personally seen 3 intank pumps fail within 2 years of installation. You would never know it from external appearances or how they sound. The only way to tell is to remove it and inspect it. The failure mode is that the rubber hose that connects the pump to the fitting splits. Not only does this make the pump ineffective but it also allows the possibility of grit and other foreign material to get into the pump... That's how my last fuel pump seized.
I would be willing to bet that if you were to inspect 3 of the in-tank pumps you have replaced in the past that are at least two years old or older, at least 2 of them will have failed as mine did in the link above. The reason is clear. Bosch/Porsche are using the wrong material for that little hose that connects the pump to the tank fitting = P.O.S.
#34
Former Vendor
While I don't "drag" vehicles back in to recheck the fuel pumps, I can tell you this....every single one of my strokers still has the in-tank pump still running. That's a quick cross-section of samples....100% running....and a bunch more than just three.
#35
Greg, many knowledgeable 928 owners all over the world who have replaced new in-tank pumps have had the connecting hose fail within 3 or so years of normal use. Just because a pump is running doesn't mean the hose is not cracked. Mine ran fine for years until one day the main pump sucked a piece of the dead rubber hose in and jammed it. Some theorize that the hose was molded using an outdated rubber formulation which is not compatible with the ethanol that is being added to gasoline nowadays. If the hose is replaced with a piece that is made from a more suitable material, there are no problems.
Dan
'91 928GT S/C 475hp/460lb.ft
Dan
#37
Former Vendor
Dan
Dan
That would be silly to do/suggest to people.
I'm betting that people who have super stiff suspension have more problems with the hose breaking....since the resulting inertial increase would "lever" the pump/strainer part of this assembly more....
#38
Supercharged
Sorry Greg, but without visual inspection, you cannot say with certainty that those in-tank pumps are still running in proper order. My car ran fine with the broken pump... Only found out it was broken when we pulled it.
But I think you are right that the additives in our gasoline these days is mostly reponsible for the degradation of that little hose. But I do not add anything to my gasoline. So it's not an isolated case. Do your strokers use pump gas or race fuel? I think there is less ethanol is race gas, but not 100% sure on that. Could that account for our different experience?
Also, looking at the Bosch spec sheet on the 044 pump, there is no mention that it requires a Pre-pump or some inlet pressure. So I think your statement that it is designed to have an in-tank pump is merely to support your claim that the in-tak pump is a good thing, and not based on fact. Sorry to call you on that, but the Spec sheet doesn't support your claim.
http://www.bosch-motorsport.de/en-US...6821238411.pdf
#39
Are there any vehicles using the 044 pump as original equipment? If so, do they have an internal pump feeding it?
If the internal pump isn't capable of flowing as much as the 044 pump, it seems like it's basically just a restriction limiting the flow capacity of the 044 pump. That wouldn't be a problem on engines that don't make enough horsepower to need all of the 044 pump's capacity. If that's the case, I don't really see any need for the 044 pump in the fiirst place for those engines.
#40
Former Vendor
I'm not sure I said that the 044 pump requires a pre-pump. If I did, it was certainly not what I intended to say. I've been running the 044 pumps, for years and years without a pre-pump. None of the Cup Cars feeds fuel to their 044 pumps....however, I'm not sure we've ever been concerned about fuel pump noise in a race car....which is what this thread is about.
I also don't think the pre-pump will hurt the 044 pump, so I always retain that pump, when adding an 044 pump into a 928. I think that this keeps the 044 pump significantly quieter.....which is what this thread is about.
I did say that the '89 and later primary fuel pumps require a pre-pump and if someone wants to "remove" the pre-pump on these cars, they should use the primary pump from an '87-'88 vehicle....unless they want a noisy pump...which, again, is what this thread is about.
#41
Supercharged
Found this interesting comparison on genuine Bosch 044 pumps and fake ones.
http://honda-tech.com/showthread.php?page=2&t=2710307
#42
Nice link. Thank you .
OK. I am pretty sure mine are real at this point... at least the one from Roger I am 99% is real. I need to relook at the first one I got from Amazon to make sure, but I think it was Czech.
#43
Former Vendor
These pumps require quite a bit of current and it is feasible that your wiring is getting hot and the pump could be getting marginal current.
The other thing that you need to think about is if you really "need" all the trouble that a 044 pump brings? The stock pump will "support" a minimum of 380rwhp (through an automatic) and 425rwhp (through a five speed.)
Real horsepower.....not "dream-o-meter" horsepower.
Not many 928s are actually making that kind of power.
#44
Are you running the 044 pump through the original fuse and wiring, or did you add a power relay and a 12 volt power siource directly from the battery?
I did not add a power source of new relays. All off of stock. Any link for how to do this best? I will do that next.
If that does not work, I think I will go back to the original external pump... but I am still unclear if I need to add the internal pump back in or leave the filter.... These are stock and I will not be adding a SC to them. ... thoughts....
#45
Former Vendor
I do not believe that I need it for HP. When I discussed the need for a pump before, the 044 was the overwhelming recommendation with the tank delete filter. That is why I purchased them for both of my 89s. I am not running more than stock HP at best.
928, also.
Check with Roger at 928's R US or with 928 International. Both of those companies distribute my products, or might have their own installation "kits".
I think someone really gave you poor advice. Running that huge pump, for a stock application, is way more overkill than anyone should ever do. If you have an unused pump, I'd suggest that you ask the supplier if you could exchange it for a "stock" style pump that will run with the stock wiring...way easier and way less "load" on an already "strained" alternator.
As I mentioned earlier, in this thread, there's a stock 928 pump that was designed to be used without the "pre-pump". This is found in the '87 & '88 vehicles.
928 608 104 02 gets you the correct pump.
