928 Forum 1978-1995
Sponsored by: 928 Specialists
LSD drain plug - metal filings
Old Jan 30, 2012 | 09:54 PM
  #31
Bill Ball's Avatar
Bill Ball
Under the Lift
I drained the diff fluid again today after another 100 miles and it looked clearer and there were no more metal filings on the drain plug magnet. I replaced the Redline 75/90NS with Mobil 1 LS. IMMEDIATELY the shuddering was gone. I don't know for sure if that is a good thing, but it no longer shudders on parking lot maneuvers. If I had a little more horsepower, I'd do a burnout and see if I get 2 stripes.
Old Jan 30, 2012 | 10:07 PM
  #32
sgschroeder's Avatar
sgschroeder
My 2 cent's worth-
Redline 75/90 NS is NOT the proper choice for an LSD!!! Either use 75/90(NO NS) or add Redline friction modifier. 75/90 NS has additives to enhance old LSD's friction Co-Ef and/or help older synchros. It is typically used in open-diff transaxles that share the same lubricant.
Old Apr 19, 2012 | 02:15 AM
  #33
Bill Ball's Avatar
Bill Ball
Under the Lift
Originally Posted by sgschroeder
My 2 cent's worth-
You are quite right. So, the Redline response to James was incorrect. It's even clear from the bottle label information that we should be using 75/90 without the NS designation.
Old Apr 19, 2012 | 02:29 AM
  #34
NoVector's Avatar
NoVector
Would the same be true for systems with a PSD?
Old Apr 25, 2012 | 05:02 PM
  #35
SteveG's Avatar
SteveG
This was never answered. I will PM Gregg just to be sure.
[Later] Gregg says he knows of no other "requirements" for the PSD, so his earlier recommendation stands.
Old Apr 25, 2012 | 05:17 PM
  #36
Bill Ball's Avatar
Bill Ball
Under the Lift
I would think so. Redline 75/90 or Mobil 1 LS seem to work, and I would not use Redline 75/90 NS, at least in an automatic. I think the variable that may alter this is whether you are talking manual or automatic. As I recall Greg really likes Mobil 1 LS whether auto or stick, and didn't have a lot good to say about Redline. I have M1 in now and everything seems pretty good. ' should check the magnetic drain soon and see if there is any new metal.
Old Apr 25, 2012 | 06:24 PM
  #37
Speedtoys's Avatar
Speedtoys
I had M1 with my new tranny....noisy as heck.
I replaced with LSD safe Redline...nice & quiet.
I drive an Auto.
Old Apr 25, 2012 | 10:01 PM
  #38
Bill Ball's Avatar
Bill Ball
Under the Lift
As long as it's not Redline NS, right, Jeff?
Old Apr 25, 2012 | 10:32 PM
  #39
Dan87951's Avatar
Dan87951
Anyone know about how much replacement friction disks are for late LSD's?
Bill, good to here a fluid change got you fixed up.
