I'm a bit confused.
I have an electrical problem with my 81 928 the window driver side won't go up sunroof won't open and the remote mirror stopped operating. all occurred with in one month and I suspect it might be a ground connection and I need to find out how many there are and there locations so I can check them.
My problem I'm having difficulty generating a thread under technical section.
need guide lines,
The remote mirror,sunroof and the drivers side window stopped operating in down position within last month. Could this be a grounding problem and if so how many grounding points are there and where are they located. Would appreciate some help'
Pat
need guide lines,
Pat
Have you read this thread...? If you had you would have your answer.
https://rennlist.com/forums/928-foru...questions.html
Also WD40 will be your best friend.
Team Owner
check the fuse,
remove the console side covers and swap the right hand window switch to the left window,
see if it works,
it might be time for you get new switches ,
or take them apart and try cleaning them.
the mirror switch is probably the rocker Left right switch,
try moving the rocker a few times left to right then hold it in almost its full throw position while you use the mirror adjustment switch to adjust the mirror,
I wouldnt recommend taking the left right switch apart unless you have a new one to install as the small barrel will fly out if your not careful,
if you do try this, get a big towel spread it on the floor work on the floor
see if it works,
check the fuse,
see if it works,
see if it works,
Just thought I would add that Pat is 70 years old and could really use someone in his area to give him some help or at least take a look and direct him to a shop.
Brad
Brad
From WallyP
You might want to do the "Annual Electrical Maintenance" routine.
Sometimes it seems as if the 928 is susceptible to a lot of electrical problems. You can forestall many of these problems by doing preventative maintenance on the electrical system. While I refer to it as "annual" maintenance, once every five years will probably take care of most problems.
1) Open the hatch and remove the tool panel. Remove the carpet and spare tire cover. Remove the spare, tools, etc. Open the battery box.
2) Disconnect the ground cable from the chassis. Remove the negative battery terminal. Remove the positive battery terminal. Remove the battery hold-down. This is a curved piece of sheet metal, held by one bolt. One end holds down the lip at the bottom of the battery. Remove the battery. Use extreme caution to avoid getting battery acid or residue from the top of the battery or cables in your eyes. Goggles are recommended. If the battery brushes against your clothes, you can end up with holes.
3) Clean the battery terminals until they are bright and shiny. Dull gray won't do. If it is possible to check the fluid level in the battery, do so. Fill to the rings. Wash the battery. Put it on a charger if possible.
4) Clean the battery box, removing all corrosion. Wash the battery box - baking soda neutralizes the battery acid. After it dries, touch up the finish as required.
5) Clean the battery cable terminals (all three) until the connection area is clean and shiny. Dull gray won't do. Clean the connection area on the chassis. Carefully check and clean any other connections on the positive battery terminal. On later cars, these are very critical power supplies for injectors, fans, etc.
6) Clean the electrical connector in the right forward corner of the spare tire well. Depending upon the model year and transmission, this connects speedometer drive, neutral start switch, gear indicator lights, etc., etc. This is an important connector.
7) Raise the hood (bonnet). On the right fender panel, find the jump start terminal. Remove the protective cap from the jump start terminal and pull the protective plastic cover from the terminal. If you are missing the cover or the cap, replace them - they are critical items. If there is no cover, water will enter the connector and corrode the connectors and wires, causing serious electrical problems. There should also be a short piece of plastic trim clipped to the edge of the fender flange just above the terminal to divert wash water and rain water from the connections. If the connections are clean and tight, replace the cover and cap. If the connections show any trace of corrosion or any looseness, disassemble, clean and reassemble. Much of the electrical power for the car flows thru these terminal connections.
8) Find the fourteen-terminal connector near the jump start terminal. This is a common trouble spot. While I suggest that you disassemble and clean these connections, be aware that the wires can and will fly in all directions if you are not very careful. I would suggest digital photos before and during disassembly! Clean all of the connections, and check for corrosion running up inside the wire insulation. Reassemble the connector. (In an emergency, you can jump power from the jump start terminal to the yellow wire in the corner of the connector to operate the starter. Be aware that the starter will operate with the car in gear, and the car will run over your foot.)
9) Jack the right front of the car and support it so that you can SAFELY work underneath.
10) Remove the ground cable that runs from the right side of the engine to the chassis. Clean both ends of the cable, and check for corrosion in the cable. Clean the connection points, and replace the cable.
11) Check the heavy cable connection on the starter solenoid for damage, looseness or corrosion.
12) Check the moderately heavy wires on the same connection for corrosion and breaks inside the insulation. These carry the charging current from the alternator and from this point to the jump start terminal.
13) Check the small yellow (may look brown, cream, etc.) wire connection for corrosion and tightness. This wire triggers the starter solenoid.
14) Lower the car. Fold back the carpet and open the central power panel cover.
15) Check the main power connections at the top of the panel for tightness and corrosion.
16) Check the ground connections above the panel for tightness and corrosion.
17) If you do not have a diagram of the fuses and relays, go to the Tips section of our web site and print the correct chart for your car. If you have round fuses, carefully clean the fuse clips, and make sure that the fuses fit tightly. If you have the newer plastic fuses, remove each in turn and make sure that the fuse connectors fit tightly in the connectors. Check each fuse for the proper value, and examine them visually for damage or corrosion. Any trace of overheating of the fuse or its connector is a definite indication of a bad connection, and must be corrected. NEVER use cheap fuses! Cheap imported fuses have failed to blow under overload conditions, causing damage and fires. While you can test fuses with an Ohmmeter, it is easier to test them with power applied. Later cars have a fuse tester built into one of the relays. You can touch the tiny metal bits on the face of the plastic fuses with one probe of a voltmeter/multimeter (other probe grounded) - you should have power on both bits or on neither bit, depending upon whether the circuit is powered. You can do the same test on the older round fuses by touching each end in turn with the ungrounded probe. Again, both ends or neither end should have power.
18) If you feel that it is necessary, remove and reinsert each relay. This won't be easy, as they fit very tightly in some cases. Porsche sells a relay removal tool, but I am not impressed. It is basically a pair of pliers with square jaws, and will pull the relay apart. One tool that works well is a paint can opener, usually available free at a paint store. This is a small tool made of bent steel wire, with a loop on one end and the other end having the last 1/8" bent over at a right angle. You can put this angle under alternate bottom edges of the relay and lift it out - IF the battery is disconnected!
19) Close the panel and replace the carpet.
20) Replace the battery and install the hold-down. Install the positive cable. Install the negative cable. Put a drop of oil on each nut. Connect the chassis end of the ground (negative) cable. Lubricate the battery box latch and close the box.
21) Lubricate the wiper drive shaft and hatch latch mechanism.
22) Clean the spare tire, jack and tools. Put a couple of large heavy plastic garbage bags in the spare tire well for emergencies, along with a tube of hand cleaner and some paper towels. Nitrile gloves are really nice to have. Install the cover and carpet.
23) Lubricate the jack, and put it inside the tool panel. Clean and lubricate the tools. Reinstall the tool and tool panel.
24) Reset the clock and radio presets.
Aha, Pat is a new member. Welcome Pat. Check out the new visitor thread at the top. Good stuff in there. Find the "User CP" button at top. You can edit your signature line with helpful info about location and MY.
Thank you. Saved for future maintenance.......I liked the explanations of why it is important. It is time to order that little cover and cap for the jump terminal.
