Window Tab Installation ???
I've searched but cant find any directions on how to install the drivers side window tab. Ya know the little black, triangular, thing that keeps your window from sucking out at high speeds. It has a tab on the bottom that turns at a 90 degree angle with a screw hole for securement. How do you get in there to secure the tab to the window/door frame???
Any help would be appreciated!!
Joel
Joel
just open the window and look under the rubber you will see the screw make sure you put thee right one on the right side just did both sides on my car tonight.
Rest in Peace
Yep, just one screw, but I would really, really suggest you do this in a garage, cause if you drop that little screw in they yard or some driveways you may never find that little screw again.
Team Owner
put some stickum on the end of the phillips prior to removing the scew
3M strip caulk works well
I was thinking that it CANT BE THAT SIMPLE... nothing else is... ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Thanks guys! I'll update after I get it done in the a.m.
Joel
Joel
