928 Forum 1978-1995
Sponsored by: 928 Specialists
WTB S-4 engine
Old Jan 17, 2012 | 06:51 PM
brian944turbo's Avatar
brian944turbo
Default WTB S-4 engine
Anybody got one for a good price. Have a 87 with crank issues.
brian944turbo@att.net
Old Jan 17, 2012 | 06:59 PM
Ducman82's Avatar
Ducman82
Veteran: Air Force
I havean S3 long block for sale.
Old Jan 17, 2012 | 07:00 PM
jetrainor's Avatar
jetrainor
I'm sure there's one out there....i had the same issue with my 87 and got lucky with an 88 engine from a 5 speed. 1988 will plug right in to the 87 brains with no issues otherwise you'll have some other issues to deal with though not deal breakers. You'll find tons of other TTDWYIT....like motor mounts, Constantine's clamp to replace the stock drive shaft clamp if its an auto, etc.
Old Jan 17, 2012 | 08:49 PM
proud1's Avatar
proud1
hav a strong 85 s3!?
Old Jan 17, 2012 | 09:01 PM
brutus's Avatar
brutus
Since he has a crank problem it has to be a thrust bearing failure so automatic. Sadly far too common a problem. There are too many differences between 86/86 and S-4 long blocks to make it a good option to backdate the car.
Old Jan 17, 2012 | 09:55 PM
IcemanG17's Avatar
IcemanG17
Let me guess......an automatic S4 with thrust bearing failure.....unforunately quite common....
You need at least a crank and block (typically).....but its always better to buy a known good engine.....
Old Jan 17, 2012 | 11:21 PM
Podguy's Avatar
Podguy
Send me an e-Mail dbrindle@kondratyev.com
Old Jan 18, 2012 | 10:36 AM
MBMB's Avatar
MBMB
Didn't someone here come out with a TBF repair fixture a couple of years ago?
Old Jan 18, 2012 | 02:53 PM
anonymousagain's Avatar
anonymousagain
pretty nice on eBay http://www.ebay.com/itm/320831317461?item=320831317461&viewitem=&vxp=mtr
Old Jan 18, 2012 | 02:54 PM
anonymousagain
this one's really low miles, but $$$$ http://www.ebay.com/itm/ENGINE-1987-...item2316122c6a
might try International as well (you never know)
Old Jan 19, 2012 | 03:10 PM
brutus's Avatar
brutus
Really high $$$ with this statement.." WHAT TO EXPECT WITH YOUR ENGINE?
Engines are sold as a long block only, with accessories and transmissions sold separately. Accessories not included, but can be purchased separately are alternators, starters, compressors, steering pumps, coil packs, turbos, super chargers, distributors, and throttle bodies. "
No intake manifold !!
Old Jan 19, 2012 | 06:00 PM
heinrich's Avatar
heinrich
928 Collector
I have a GTS engine (complete) that I'm disassembling and will likely be selling as a complete but disassembled engine.
Old Jan 20, 2012 | 04:36 AM
Podguy's Avatar
Podguy
Why?
Old Jan 20, 2012 | 10:44 AM
Ducman82's Avatar
Ducman82
Veteran: Air Force
any difference besides heads on an S3 to S4?
Old Jan 21, 2012 | 05:12 AM
Podguy's Avatar
Podguy
There are a number of differences to the block to accomodiate the newer manifold. it is possible to put the S4 manifold on the S3 engine. Unless you changed the LH unit the flappy will be disabled.
Now if you want a real hybrid engine put a GTS bottom end on with your heads. The GTS is an S4 engine with a stoker crank. Porsche was at the limits for boring so they had to increase the stroke to get the extra .4 liters. Of course you will pay the price of a slower rev up. Longer strokes take longer to rev than shorter strokes. But the horsepower will more than make up for it.
Then again you can add steel sleeves and 968 pistons I think it is and get 6.5 litters. Although I do not thiink anyone has been able to keep one of these running for very long.
The S4 heads have bigger valves than the S3. But the S3 cam is a little hotter. Some people have put the S3 cams on the S4 motor. But as I understand it they need to be cut.
