PSA: alloy vs coppy 'torpedo' fuses - an observation
What I can imagine as practical might be to use a secondary small panel with circuit breakers hardwired to the old ceramic fuse connections.
Electron Wrangler
Ideally some replacement terminals would adapt the exsiting slots - (likely these need to be custom made). Even then I think there would also need to be a secondary terminal retention mechanism (likely custom made from an insulator - probably plastic). This rentention mechanism can likely also serve as a terminal cover for electrical protection.
Now some simpler adaptations - using off the shelf commercial multi-way fuse blocks could also be done but this would be rather less elegant.
Alan
