Potentiometer Style TPS
Man of many SIGs
I am doing a megasquirt conversion and I need to fit a potentiometer style throttle position switch to the engine. I am using a Euro LH throttlebody. It came with a TPS that from what I understand is just a three position microswitch. It's part number is Bosch 0 280 120 301
I am wondering if anyone knows of a way to cross reference this TPS and find one that fits the same but is of the potentiometer style. I planned on going to the auto parts store and hopeing that they would let me open box after box but I'm sure the knowledge base that makes up Rennlist may already know what I need. How would I determine whether or not a TPS is or is not of the potentiometer variety? Any help you can offer is greatly appreciated.
I've found this link to be very useful for this:
http://www.bosch-motorsport.de/conte.../html/2910.htm
HTH,
-don
HTH,
-don
Inventor
951 TPS, 951 606 113 00, 0 280 120 400
http://www.lindseyracing.com/LR/Pors...06-113-00.html
I bought a used one off eBay.
Late GTS TPS are variable, but IIRC, S4-up TPS rotate the opposite way vs. S2/S3.
Man of many SIGs
Regarding the rotation. I believe the 85-86 32v rotate clockwise but I'm pretty sure ( not 100% ) that the S4 rotates counter clockwise. Meaning the S4 throttle pulls straight back but the 85-86 has a bracket up front that causes the throttle cable to pull towards the front of the car. <-- is that clear as mud?
Inventor
1,2,3 are for the variable resistor. 4,6 are the idle switch.
I have in my notes that several folks doing MS conversions recommended:
Volvo 850 TPS 0-280-122-001 DELPHI Part # SS10321
or
1993 Porsche 968 Bosch # W0133-1618872
HTH,
-don
or
HTH,
-don
Man of many SIGs
http://www.ebay.com/itm/Delphi-SS103...item4aabf1c75f
Man of many SIGs
I looked 1994 PORSCHE 968 3.0L L4 : Fuel/Air : Throttle Position Sensor (TPS)
on rockauto and it shows both the Bosch with that number and the Delphi number, so I'm guessing they cross reference.
-don
-don
Man of many SIGs
OK, I've purchased the new Delphi unit and a used 951 TPS as well. I'll take a look at them, test them and report back here for future generations.
Thanks everyone for your help with this.
