Towing eye thread cleaning tap useful ?
#196
Chronic Tool Dropper
Los Angeles area 928 owners: The tow-eye tap is soon to be on its way over to Europe for its maiden Euro tour. Before it goes, we have a last opportunity to use it over one weekend between now and late April. This coming weekend is out because of Easter, and the following Saturday 4/6 is booked for an Amish barn-raising on the UCI campus. That leaves 4/13 and 4/20 Saturdays, 4/7 and 4/14 Sundays. If you need to clear the threads for the front tow-eye, and have a later 928 with the larger threads in the tow-eye socket, here's the last convenient opportunity we'll have for a while. We have a lift, drills, relatively clean and convenient workspace, along with BTDT guidance and support. It doesn't get a whole lot easier. If you have an interest in taking advantage of this opportunity, please post here with your preference on date. If we don't see responses in the next few days, our reserved space on the wait-list will be relinquished and the tap will start its journey east to the European owners who are waiting for it.
#197
#198
I'll be waxing the undercarriage of the Honda if we don't fix some 928 tow eye threads.
#199
Electron Wrangler
Dr Bob - unless you have had direct PM interest ... seems this one has GONE!
Seems I should make plans for the "European Tour" to kick off immediately on its return.
Alan
Alan
#200
Thanks for coordinating this program, and holding the slot open for me!
#202
Electron Wrangler
My thanks to John Pitman for comissioning and loaning the tap
My thanks to Ernie Byrnes who actually made the tap
My thanks to Ed Scherer for donating a 21/32" drill
Plus my thanks to those who have set up group use sessions to maximize coverage...
THE LIST so far:
0 jp (Melbourne, Oz)
1 Vic (Melbourne, Oz)
2 Dave928S (Kingston-Tasmania, Oz)
3 CraigL (St. Louis) -> $50 Rcvd - Tap Sent 2/7/12 -> Delivered 2/10/2012 -> Craig $32.20 (gross) refunded to your Paypal.
- 4 byrdman454 (St. Louis) Sent Back 2/21/12, Rcvd 2/23/12
5 AO (Nr. Detroit) - >$50 Rcvd - Tap Sent 2/26/12 Rcvd 3/24/12, Andrew $32.20 (gross) refunded to your Paypal.
6 Whitesands (Florida Panhandle) >$50 Rcvd - Tap sent 3/26/12, Rcvd 4/06/12 Ivan $32.20 (gross) refunded to your Paypal
7 90 S-4 (OC - California) $50 Rcvd - Tap sent 4/7/12, Delivered 4/9/12, Joe $32.20 (gross) refunded to your Paypal
- 8 Rob Edwards (Irvine CA) Sent Back 4/11/12, Rcvd 4/13/12
9 jthwan22 (Central NJ) $50 Rcvd - Tap Sent 4/13/12, Delivered 4/16/12, Rcvd 4/23/12 James $32.20 (gross) refunded to your Paypal.
10 Donald (Houston Area) $50 Rcvd, Re-Sent 10/23/12 - Repair done! Rcvd 11/19/12 Donald $32.20 (gross) refunded to your Paypal.
11 fraggle (Northern VA) $50 Rcvd... Tap Sent 11/20/12 Delivered 11/23/12 Rcvd 12/17/12 Michael $32.20 (gross) refunded to your Paypal
12 auzivision (Indianapolis) $50 Rcvd, Tap sent 12/20/12 Rcvd 1/14/13 Kurt $32.20 (gross) refunded to your Paypal
13 M928 (Niagara County NY) $50 Rcvd, Tap sent 1/15/13 Rcvd 1/22/13 Mark $32.20 (gross) refunded to your Paypal
14 Ed Scherer (Nr Kansas City) $50 Rcvd, Tap sent 1/23/13 Rcvd 1/31/13 Ed $32.20 (gross) refunded to your Paypal
15 shadowknight (Clearwater FL) $50 Rcvd, Tap sent 1/31/13 Rcvd 2/28 Gary $32.20 (gross) refunded to your PayPal
16 Stromius $50 Rcvd, Tap sent 2/28, Rcvd 3/7 Stefan $32.20+ shipping (gross) refunded to your PayPal
-> PacNW Tow Eye Tap Party Fixes: 17 Tom M, 18 Mark J, 19 Andrew, 20 Adam (all drilled out/repaired)
-> Jim/Sue, Tom R & Brian just cleaned theirs out.
21 Ammonman (Springdale, AR) $50 Rcvd, Tap sent 3/8 Mike $32.20 (gross) refunded to your PayPal
22 philesk (Berkeley, CA) $50 Rcvd, Tap sent 3/21/13 Phil $32.20 (gross) refunded to your PayPal
Seems our whole USA list is done for now -> Next stop Finland!
Alan
THE LIST so far:
Alan
#206
Rear of front tow hook
I have asked before, but did not get an answer.
Can anybody tell me how to access the rear of the front tow hook so as to put some penetrant into the hole to see if the tow hook plug can be persuaded out.
#210
Archive Gatekeeper
Per jpitman2:
https://rennlist.com/forums/928-foru...l#post10756951
EDIT:
More specifically, http://www.gewinde-normen.de/en/knuc...d-din-405.html I like the comment about knuckle threads being insensitive to dirt. Except for knuckle threaded aluminum plugs in steel.....
Sometime around 86 the thread changed from what Porsche call 15mm x 8 threads per inch (knuckle type RD14 - 14.318mm, 9/16" OD) to 20mm x 8 tpi (Knuckle RD20, 20.318mm, 0.8" OD x 8 tpi). An 82 should have the 15mm thread (my 83 has this). Here is a link to the specs:-
EDIT:
