928 Forum 1978-1995
Sponsored by: 928 Specialists
Dashboard lights dimmer
Old Jan 9, 2012 | 11:48 PM
Bjbpe's Avatar
Bjbpe
Default Dashboard lights dimmer
My dimmer wheel under the pod has no affect on the pod brightness. Can somebody tell me where to look first (and second and third).
Thanks.
Old Jan 9, 2012 | 11:52 PM
Speedtoys's Avatar
Speedtoys
Mine was iffy, then I sprayed some de-oxit up there, and it works much much better.
Could also..not knowing a better way...pull the plug on it, and test for 12v to it as well.
Old Jan 10, 2012 | 12:56 AM
Spun's Avatar
Spun
you can bridge it or do what I just did today, buy a new one. They are $75, but its worth it to have all the lights back.
Old Jan 10, 2012 | 01:27 AM
heinrich's Avatar
heinrich
928 Collector
Just buy any rheostat. It is a simple 12V rheostat. Just find a good way to mount it.
Old Jan 10, 2012 | 07:21 AM
993turbo's Avatar
993turbo
You dont write which car you have. If its a pre- digital intrument car the dimmer kan be easily fixed. If its the later unit its easier to change it. :-)
Old Jan 10, 2012 | 12:44 PM
Luis_M's Avatar
Luis_M
I can't speak to later cars, but here are the details for my early car. I just "refreshed" my non-op dimmer this week on my 1981 S Euro, as I had no dash or clock lights at any dimmer position. If the clock light works but not the dash, it is unlikely to be a dimmer problem since both the dash lights and clock light feed off the output of the dimmer.
There are two plastic pins on the back of the dimmer unit fitting into the underside of the dash and the whole thing is tightened down with a Phillips-head screw. You can wiggle the dimmer out after loosening the screw -- I'm guessing it would be a pain to rethread if you take the screw all the way out since it's pretty far up there. Two spade-type electric plugs (One is 12v in from the light switch, the other has 2-leads going to the dash lights and the clock light) on the side of the dimmer.
There was lots of oxidation on the underside of the sweep contact at at the "full-on" contact preventing current flow. The resistive wire coil part looked fine. I slid some fine grit paper between the wire and the sweep contact (grit towards contact) and ran the wheel back-and-forth 5 or 6 times to sand off the oxidation, then wire-brushed the flat full-on contact at the end of the wire coil. After cleanup, I checked the resistance with my meter (0 ohms at full on, about 18 ohms at dimmest setting), sprayed a little Dexoit (great stuff!) on the wire coil and on the contacts, popped it back in, and, thankfully, all dash/clock lights restored. Time=15 minutes.
Old Jan 10, 2012 | 01:20 PM
Ed Scherer's Avatar
Ed Scherer
On my '90, the dimmer rheostat looks like this:
On closer examination, you'll see that there is a lower wiper that contacts the resistor coil and there's also an upper wiper.
And, FWIW, on the '90 (and I'm guessing many other model years), any break in the wires to this rheostat (or if the rheostat is internally not making contact) will prevent the instrument lighting from illuminating all all when the main headlight switch is in any position other than off.
I used pure DeoxIT (not the spray kind, the D100L kind; I'm guessing both would work, but I just happen to use the 100% kind) on both of those contact surfaces and mine works nice and reliably now.
Old Jan 10, 2012 | 03:11 PM
jetrainor's Avatar
jetrainor
Would somebody splain me what de-oxit is?........my dimmer works but is iffy.....
Old Jan 10, 2012 | 04:04 PM
Ed Scherer's Avatar
Ed Scherer
See Caig Lab's page DeoxIT® D-Series - Contact Cleaner & Rejuvenator.
Old Jan 10, 2012 | 04:15 PM
Speedtoys's Avatar
Speedtoys
I deoxit'd mine, and the swiping area of the dial works much better.
But I go dark at FULL bright. Will pull that sucker sometime...
