Ernie after careful inspection my paint sticker has only 3 lines the top row is the paint code the second and third rows are to color there isnt any other marking in the foil to indicate a forth line
Please check your spelling as the correct spelling on the sticker is as follows
11H 9 3
ELFENBEIN
PERLGLANZ
Thanks for your time, Stan
Ok,lol I'll throw that "E" in the garbage,so after reading my last reply if you still want one let me know & I'll pm you with the infos needed.
Mine is like MrMerlin's - only 3 lines. Kind of related, is there anything that can be done for the barcode label? Thank you / Bruce
Thank's for the infos Mrmerlin's ,the barcode label could always be done ,problem is will be the size which neither me or G1 has & the prize which will be different from the color code decals & frankly I rather not go in into those yet.
Here's the paint labels for my 3 cars that Ernie just had made for me. I couldn't be happier with how they turned out. As though they came straight from the factory, only better since they are not the frail foil ones. Thanks Ernie!
