928 Forum 1978-1995
Sponsored by: 928 Specialists
930S Steering Wheel Installation Instructions?
Old Dec 28, 2011 | 03:57 PM
IrishLegend's Avatar
IrishLegend
Default 930S Steering Wheel Installation Instructions?
I have searched to no avail. Does anyone have a write-up or a link for this?
Thanks,
Old Dec 28, 2011 | 04:59 PM
928mac's Avatar
928mac
I believe I just removed my horn pad, removed the nut, and replaced the wheel.
I know that there is more to it then that. Are you looking for step by step for a newb? or was there something eles that you were wondering about?
Old Dec 28, 2011 | 05:02 PM
Shane's Avatar
Shane
Sharkaholic
Disconnect Battery
Pull horn pad off, give it a good yank.
Disconnect Horn Wire from pad.
Use a 1 1/16" deep well socket to undo Steering wheel nut
Slide stock wheel off splined shaft
If you have one use a steering rack centering bolt to center the steering
Slide new 930 onto splines after removing horn pad
Unscrew metal contact ring to give access for installing nut
Install nut and washer
Reinstall contact ring
Reinstall horn pad
Reconnect the battery
Don't forget the centering bolt in the steering rack
Drive!!
Old Dec 28, 2011 | 05:36 PM
IrishLegend
Thanks!
Old Dec 28, 2011 | 06:28 PM
928mac's Avatar
928mac
here is another right up on nicks page
http://nichols.nu/tip467.htm
Old Jan 6, 2012 | 08:24 PM
IrishLegend
Horns not working? Any ideas?
I removed the horn relay to start, then replaced wheel hooked up female wire connector to male on steering wheel and replaced relay and nothing?
Old Jan 6, 2012 | 09:27 PM
IrishLegend
Fixed. New relay.
Old Jan 6, 2012 | 09:34 PM
SeanR's Avatar
SeanR
Call me.
