928 Forum 1978-1995
Sponsored by: 928 Specialists
Upper Control Arm Nuts
Old Dec 27, 2011 | 02:38 PM
Tom in Austin's Avatar
Tom in Austin
Default Upper Control Arm Nuts
Curious if anyone knows ... when you replace a front UCA, what is the correct torque for the nuts on either end of the UCA shaft? (not the ones that hold the assembly to the body, those are 104 ft lbs) ...
Are the nuts on the ends of the UCA shaft the kind that should be final-tightened with the weight on the wheels?
I think I remember Bill Ball mentioning this in the past, but couldn't find a definitive answer.
Old Dec 27, 2011 | 03:11 PM
Bilal928S4's Avatar
Bilal928S4
Yes. However once the car is on its wheels there is no access to those nuts.
Bilal
Old Dec 27, 2011 | 03:47 PM
Imo000's Avatar
Imo000
Captain Obvious
Super User
That's why you lift it with the wheel off and jack under the lower ball joint.
Old Dec 27, 2011 | 04:01 PM
Tom in Austin
And the correct torque value ?
Old Dec 27, 2011 | 04:09 PM
Imo000's Avatar
Imo000
Captain Obvious
Super User
I'm sorry but I can't help you with teh torque value. The only thing I torque to spec are the head bolts. These large nuts would fall into my "good n tight" category.
Old Dec 27, 2011 | 04:30 PM
Lizard928's Avatar
Lizard928
iirc they are M12x1.5 thread.
I would expect them to take around 65 ft lbs.
But looking through the manual I cannot seem to locate a specific torque value for them.
Old Dec 27, 2011 | 04:34 PM
NoVector's Avatar
NoVector
If you're talking about this nut (for the bolt that goes through the bushing), I used 63 ft-lbs. I think I also used some blue thread locker. I used 63 ft lbs as it was the same torque as the lower bolt that goes through shock bushing--but like you, I couldn't find it in the WSM. Carl has a UCA guide on his site, but unfortunately, it doesn't have the torque value either. Good luck! / Bruce
Old Dec 27, 2011 | 04:35 PM
Leon Speed's Avatar
Leon Speed
Couldn't find them either when I replaced the upper A-arms. I made sure they were nice and tight.
Old Dec 27, 2011 | 07:36 PM
Hilton's Avatar
Hilton
There is no factory torque value because they're not meant to be undone - the whole upper control arm assembly is provided as a single unit from Porsche.
Having said which - I went with 65ftlbs based on the thread pitch (M12x1.25 from memory - too lazy to go measure one downstairs).
It is worth replacing the nuts with new - IIRC, they're cone lock and after a few undo's, lose a lot of their locking friction (like a lot of the suspension nuts).
