928 Forum 1978-1995
Sponsored by: 928 Specialists
Injector options
Old 12-25-2011, 07:44 PM
Ducman82
Ducman82's Avatar
Default Injector options
Got my LH spider from England yesterday (best Xmas gift ever) , but I'm not sure what injectors I will need..... For my L-jet set up I got Carls L-jet " replacement" injectors but I had to drill out the holes so they would fit, due to the ledge u see just inside the injector hole. I don't mind milling the hole out, just need to do it before they get cleaned and coated.
Old 12-26-2011, 07:06 AM
John Speake
John Speake's Avatar
The Euro LH runners are for the 24# high impedance barbed top hose connection. What power are you aiming for ? Boosted ? Using the 24# injectors and S4 FPReg at 55psi as against the S2 35psi may be enough for a mild power increase. (You will get 25% more available fuel flow)
Old 12-26-2011, 09:14 AM
Ducman82
Ducman82's Avatar
I'd like to get away from barbed Injectors, thinking of boost in the future. But injectors are easy enough to swap. Looks like I will need to do some drilling! :-)
Old 12-26-2011, 10:44 AM
toofast928
toofast928's Avatar
All Bosch style injectors will fit the intake runner hole, I use 48# Venom Injectors. Just change the pintle cap, make or purchase a fuel rail, and convert the EMS
Old 12-27-2011, 11:21 AM
RCinXS
RCinXS's Avatar
Old 12-27-2011, 12:53 PM
Ducman82
Ducman82's Avatar
can you get the pintle caps and seals still? i don't have old injectors...
Old 12-27-2011, 02:28 PM
John Speake
Yes
Old 12-27-2011, 02:45 PM
U-928
U-928's Avatar
Good timing on this thread, I was in the exact same boat.
Old 12-27-2011, 05:58 PM
Ducman82
Ducman82's Avatar
I do what I can
Old 12-27-2011, 08:58 PM
atb
atb's Avatar
Thanks for the heads up Tony. Does that mean any high impedence injector will work in an L-Jet manifold as long as you use the stock low impedence pintle cover on the new injector? (I'm planning on using a different fuel rail)
Old 12-28-2011, 01:13 AM
toofast928
toofast928's Avatar
Adam L-Jet are low impedance, you can not use hi impedance injectors with L-Jet.
I'm using Haltech EMS and changed the pintle cap to accept Bosch one hole hi impedance injectors, (the Bosch injectors in the pic are high impedance). Made my own fuel rails to accept the o-ring top injectors.
You can still purchase low impedance injectors that flow more than the OEM 24#. But L-Jet is so old and I bet your engine wiring harness is starting to crumble time to upgrade everything.
Tony
Old 12-28-2011, 04:17 AM
danglerb
danglerb's Avatar
Tony
Low impedance = high drive current.
High impedance = low drive current.
I think it works backwards to what you said, you can't use a low impedance injector with a high impedance brain, but either work with a low impedance brain.
Old 12-28-2011, 03:57 PM
toofast928
toofast928's Avatar
Danglerb thats not correct.
ECM controller has a specific injector ohm valve. Injector values are not interchangeable.
Old 12-28-2011, 04:09 PM
Fabio421
Man of many SIGs
Fabio421's Avatar
ECM controller has a specific injector ohm value. Injector values are not interchangeable.
Not to mention you would have a hell of a time finding a high Impedence barb style injector. I've spoken to a couple of injector rebuilders and they swear that there is no such thing as a high impedence barb style injector. When I tell them about the LH Euro's from 85-86 928 they just shrug and say it is very rare.
Old 03-11-2012, 11:27 PM
Ducman82
Ducman82's Avatar
what is a good way to calculate how much fuel pounds per hour is needed?
Quick Reply: Injector options
