Engine coming out for Head Gaskets and WYAIT's - UPDATE: Heads back on!
#61
Received 1,603 Likes
#62
Great Pics, thanks for posting, but where's the bling on the cam covers?
I see you are using your original cam sprockets, with all the talk about these parts lately I was wondering if the later ones are interchangeable with euro engines, I would think they would be since the belts are the same shape and all.
As for the cam gears, mine looked good, so no reason to consider others at this time. Not sure about compatability with the ones you pictured.
#63
Very happy with the progress and experience. I would have been stuck on day one without Dave.
#64
Is this pitting on heads due to corrisive water coolant? It looks like the heads were filled and re-machined some time in its life. The pits look like they were from the repair and not the coolant since it is located inside the head ring. The gaskets actually looked much better on this head than the other "clean" head. Is the concesus to replace the head then?
#65
Livio - I can't comment on your heads, but you might get a better response and visibility to your question by starting a new thread with a title specific to your question. More of the folks with the appropriate knowledge would be more likely to see your question.
#68
Team Owner
it looks good from here nice work.
If you want a small project remove the HCV water outlet and scuff the aluminum and the portion where where the tube fits into the housing about 1/2 inch should do then put some blue tape around the aluminum and let the tape sit around the tube then fill it in with some JB weld let it cure then reinstall the outlet,
this ought to prevent the metal tube from sliding out at a future time.
Or you could try to remove the metal tube and Jb weld it to the outlet
OR replace it with the updated part.
Also consider removing the power
steering pump and alternator,
as these may make installation difficult
and the radiator should also be removed
Goodluck with your project
#69
Nice work guys.
#71
The engine is back where it belongs. The radiator and clutch still need to go in, and a few more connections to make. Then we will add fluids and test for leaks, then see if she runs. I'm not sure what I will do with all of my free time once this is done
#72
Looks great!
#74
I spy a new heater valve.
Are those white things in the last pic steering rack bushings? Is that what they are called and are they different from stock? delryn or something.
Oil pan looks nice and clean. You know a clean engine should stay cooler, it gives off its heat in a much more efficient way.
#75
Thanks guys.
Yes, new heater valve/short hose, just because it was easy and cheap (old one was working fine). There is much more new hidden in there as well - mostly maintenace and rubber type stuff, although everything looked really good for being original to the car. It appears that nothing had ever been touched, except for TB/WP, plugs and filters.
Those are new Delrin rack bushings. This was a lesson learned where I probably should not have fixed what wasn't broken. The old, original bushings were in very good shape, but once I started trying to remove one, there was no turning back - and getting the old ones out was more than I had bargained for. We had the motor and mounts out with the rack still attached, but hanging. Once I started screwing with removing the bushings, we realized they weren't coming out without removing the rack completely and pressing them out. Should have left well enough alone. I am learning to pick my battles....
