Sun roof Delete?
#31
Not the sharpest tool in the shed
The non-sunroof panel is non structural - it is so thin you can actually bend it by hand. The bracing inside is non-structural either - it really is there to support the sunroof panel and not brace the body of the car. My bodywork guys rated it as a 5/10 job in terms of difficulty. They hated welding the new panel in because of the extremely poisonous zinc fumes... ....
#32
You are right, should have been more precise in my statement - it was a 5/10 on a race car, with a cage already welded in. It was never meant to be a concourse car, thus we did not even paint the inside of the panel...
#33
S4ordie and Cherburator, Thanks for the info and the pics. Now as if that weren't enough....could you provide part #s and any other resources. Please? Thanks and Merry Christmas to all of Rennlist and Family. Brian
#36
LEADASS,S4ordie & all,there are pics already posted on Chuck "Z"'s sight..928 Registry #0104 when I owned it last time 1,500 miles ago..Museum Piece for sure & perhaps the rarest GTS in this country total package, especially when you factor in the 5 speed numbers !! Expensive,but for sale !!!
![typing](https://rennlist.com/forums/graemlins/yltype.gif)
#37
LEADASS,S4ordie & all,there are pics already posted on Chuck "Z"'s sight..928 Registry #0104 when I owned it last time 1,500 miles ago..Museum Piece for sure & perhaps the rarest GTS in this country total package, especially when you factor in the 5 speed numbers !! Expensive,but for sale !!!![typing](https://rennlist.com/forums/graemlins/yltype.gif)
#38
Archive Gatekeeper
Sunroof-less roof panel, 928 503 501 02 from 78-89. (changes to -03 for the antenna added in '90)
front roof frame: 928 502 383 02
upper rear roof frame: 928 502 395 02
lower rear roof frame: 928 502 393 02
In 2/2010 the -03 roof panel was available, I got one at $292. The frame pieces were all available and were $57, $84, and $78, respectively. Dunno whetehr Anderson's got any used sunroofless headliners but there are no new ones available.
Other threads on sunroofectomy:
77Tony's, linked above.
Benton's roof R&R:
https://rennlist.com/forums/928-foru...n-sunroof.html
Dan's roof R&R:
https://rennlist.com/forums/928-foru...art-3-a-2.html
#39
Its a factory leather no-sunroof headliner out of my '89 - currently out of the car for re-covering, so pics will be easy. It still has the factory leather on it and shows all the fitting holes and screw points, as well as the shape.
I believe the earlier cars have a different headliner profile due to different sun visors?
#40
Archive Gatekeeper
Hmmm. I have two vinyl sunroofless headliners in the garage right now, not sure of their 'vintage' but would assume they're pre-87, at least. Might be interesting to compare. I'll shoot some pics when I get a chance.
EDIT: Per PET, for vinyl headliners, 928 555 071 02 is 78-83, 928 555 071 07 is 84-86, and 928 55 071 08 is 87-95. Hopefully what Dan and I have will fit in an S4+ car....
#41
Dan - I'll take some pics of mine this afternoon in decent outdoor light (did I volunteer this in a prior thread? suddenly wondering)
#42
As with regards to the non-sunroof panel - only the one for cars with roof mounted aerial is available (928 503 501 03). This could be the potential source of Roger's confusion with regards to availability. Welding the hole is dead easy though.
Sadly, no liners - either vinyl or leather - for any model year are available at all...
#45
Archive Gatekeeper
So Hebert's headliner and my headliner are identical, dimensionally. Thing about Dan's is it's brand-new, so if he can find the receipt we'll know which part # it is. But the used one has screw holes in it that will be helpful to mount the new one.
Upper surface:
![](https://webfiles.uci.edu/redwards/public/Hebert%20and%20Edwards%20sunroofless%20headliners-%20top%20sides%2012-23-11.jpg)
Interior surface:
Upper surface:
Interior surface:
![](https://webfiles.uci.edu/redwards/public/Hebert%20and%20Edwards%20sunroofless%20headliners-%20under%20sides%2012-23-11.jpg)
