gas smell
#32
I think Nicole and the other suppliers have a metal replacement. While you are in the wheel well, take a look at the winshield washer tank neck; that is usu rusty and dropping junk into the tank which will plug up the works.
#34
I can't hear it pump or anything so maybe it's the fuse , I will heck it out when it gets warmer outside , I don't have garage...
#36
How did you get in or get the keys out when it was locked??
I did that 2 times before I repaired the hatch plastic catch.
I have not been able to get another key made so have been real careful that the key ring was in my hand before locking the door.
Was considering putting a pull wire near the rear license plate or drilling another hole in the door with a pop out plug to get in.
I modified the instrument cluster cover to be removed much easier and have an old key and switch to plug in to get it running, just remove a set screw to replace so the steering wheel can be unlocked.
edit: still trying to figure out to put car data in signature area.
'79 928 5spd no sun roof
