928 Forum 1978-1995
Sponsored by: 928 Specialists
Timing belt tension tool
Old 12-04-2011, 12:52 AM
  #31
blown 87
Rest in Peace
blown 87's Avatar
Originally Posted by Bjbpe
If you are constantly revving up to 5000 rpm, you probably would have toasted gears. My engine is rarely over 3000 and then only when accelerating. If your "toasted" gears are because you are constantly way up on the speed scale, well, you probably deserve the traffic tickets and the roasted gears. And, while I'm probably old enough to be your grandfather, greg, I've learned to keep the speed reasonable.
Please stay in the right hand lane and let the young at heart have a way to get around you.
PS, it is not the speed that kills the gears, it is from running loose, as I am sure yours are.
When set to the proper tension the belt on a 928 feel far tighter than any other engine I have worked on, and that is a lot of engines.
Quick Reply: Timing belt tension tool
