Pic's of my new suspension
#46
puyi,
What you say about the springs is propbably true, I asked the engineers
at the place I bought them from ( http://performanceshock.com/ ) the same
question, they said it didn't matter, maybe they knew they were talking to
a novice![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Mark Anderson could probably detect the differance if they were swapped
back and forth but the other 99.99% of us would never know.
Thanks for the tip though, next time I'm in there taking stuff apart I'll
put them on the bottom, at least it'll then look like I know what I'm doing![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Sway bar info >
"Hollow" 1-1/4" OD
pt #608-120-37.5 .120" wall w/6'' arms
Thanks,
Joe
a novice
Sway bar info >
"Hollow" 1-1/4" OD
Thanks,
Joe
#47
Joe -
I saw your car at Cars & Coffee on Saturday. I tried to find you but after spending too much time oogling the McLaren and the Aventador, I missed you. Great job on making the car looks so immaculate.
-Dennis
-Dennis
#48
Hello Dennis, really sorry I missed you, yea there's always some pretty cool stuff there.
Thanks again for your advice in helping me to pick out my spring rates -- couldn't be happier !
#49
I found this a week ago and then this thread came up, kinda cool video on springs
http://www.peddersusa.com/photoGallery/0/1/photo76
and regarding the coil over coil I have seen them both ways including this
![](http://cdn.autoanything.com/images/products/large/Suspension/kw_suspensions_coilover_shocks.jpg)
#51
I do have one comment on your intake pieces.
It appears as though you cut the bottom off the S4 intake manifold, and then milled them a little to attach the trumpets. I see the trumpets are in aluminum though.
I do hope that you have a good welder who is well versed with welding these two metals together. Should be interesting once done though.
#52
Lizard, I can see where you'd get confused, I wasn't attempting
to weld mag to alum -- the attached pics show the bottom
flanges are made from the same block of alum that the bells
were made from.
were made from.
#53
You maka me cry joe, you maka me cry
#56
That is absolutely beautiful Joe!
If you had standalone EFI on your car I would be trying to convince you to help make a VVT system for our cars.......
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
#57
ghinkel, all replated ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
58 speedster, we have something in common, I work at >
http://www.willhoitautorestoration.com/index.php
Lizard, standalone is already here and already mapped, it'll go in
just before the stroker does.
V V T -- well, I think that is over my head I'll leave it to someone else
I'd rather have an additional 2 ltrs anyway
and in case thats
not enough I have a almost complete supercharger in storage
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
#58
The front lower brace was a parts bin project, Not Carl's
I got all the parts from this place >
http://www.speedwaymotors.com/Cone-Spacers,649.html
http://www.speedwaymotors.com/Swedge...eim,53184.html
http://www.speedwaymotors.com/search...d-RH-male.html
http://www.speedwaymotors.com/search-175-6046RH.html , < there is a left & right !
$50.00 ! for everthing
The front swaybar was a parts bin project to, all parts came from this place >
http://www.1speedway.com/index.htm
http://www.1speedway.com/Swaybar_Arms.htm
http://www.1speedway.com/Swaybars.htm
I wonder what length for the lower brace you chose. I was thinking of building my own from scratch, but if it can be bought for around $50 then is this a better option.
A other question, what length and rate did you choose for your front sway bar, did you check Carl's rates or did you go for a different setup.
/Mattias
#59
MattiasH,
It was pure luck they happen to have the right length (30") or I would
have had to start from scratch as well, the $50 was for everything, the
bar, the two heim ends & jam nuts
re: swaybar rate > I copied Mike Simard
The swaybar length is 37.5" X 1.25" O.D. - Hallow
The rates are in the website
My front coilovers are 750lb , this combo is great.
Rears are 375-lb
Rears are 375-lb
